-   Tools (http://www.diychatroom.com/f29/)
-   -   How can I remove broken bit from magnetic bit holder? (http://www.diychatroom.com/f29/how-can-i-remove-broken-bit-magnetic-bit-holder-148628/)
tabatt07 06-29-2012 03:43 PM
I was using a bit extender with magnetic bit holder. When I started using it, I was amazed at how powerful the magnets were--it was tough to get a bit out. Now I've got a broken bit and can't get a good grip to pull out what's left. Any thoughts on what to do? (Temporarily) neutralize the magnet--is that even possible? drill out the broken bit? Thanks.
VIPlumber 06-29-2012 05:38 PM
Clamp the extender in a bench vise and use a pair of pliers to tug the broken bit straight out. By the by how exactly break your bit, and what kind were you using?
tabatt07 06-30-2012 06:12 AM
Thanks for the response. The bit broke flush such that I can't grab it with pliers. I was using a hole saw as part of a DIY home networking project. I let it get too hot and then it snapped. I can live with that but I'd really regret having ruined the extender.
Tom Struble 06-30-2012 07:13 AM
maybe epoxy or super glue a small nail head to whats left of the bit?need to be careful not to glue everything together:huh:
PaliBob 06-30-2012 10:43 AM
If all else fails, here is one type replacement
or you can get rid of the magnet
Or even one with a right angle
Tom Struble 06-30-2012 01:43 PM
or maybe a stronger magnet?:)
sevenlol 07-01-2012 06:11 PM
or spend 2 dollars on a new apex....
DangerMouse 07-01-2012 08:13 PM
Vise it and hit it with a torch, the magnet will die and let the bit go, and the glue holding the magnet in will burn away and the magnet will fall out too. Glue in new magnet and you're good to go.
DM
epson 07-29-2012 11:59 PM
Or use a screw extractor:whistling2:
