How Big An Air Compressor? - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-10-2014, 07:31 PM   #16
Rewards Points: 3,546
Easy answer here and numbers don't lie.Look at the specs on the nailer and see how many CFM it takes to run it then look at the compressor and see how many cfm it puts out at 90 lbs.
mako1 is online now   Reply With Quote
Old 04-21-2014, 12:45 AM   #17
CRCA Roofing Contractor
RoofingTrades's Avatar
Wow, I missed this thread. Question for you though. How many people shingling? Are you going to run a framing gun to replace your roof deck or nail down the existing sheathing? If you're just by yourself and you aren't doing anything with a framing gun, a cheap 4 gallon compressor 120psi compressor will do the trick. Try to get something oil lubricated as it will last longer. Unless you're really, really quick at shingling you won't be running out of air. You don't really need a shingling hatchet to shingle the entire roof when you have a compressor and gun at your disposal.
As far as roofing guns go, I recommend Hitachi NV45AE and the Max SuperRoofer. I've used every roofing gun there is out there and those are the best from all my years of experience and thousands upon thousands of squares I've pounded off.
Any further roofing questions feel free to ask.
RoofingTrades is offline   Reply With Quote
15 degree split, scroll compressor is hot!! bobinphx HVAC 1 06-05-2013 04:30 AM
Air Compressor Fittings - Differences? roasted Tools 3 09-19-2012 08:15 PM
Help assembling compressor jfhspike Tools 5 03-27-2011 10:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
