Home Depot BucketHead Wet Dry Vac Stopped Working - Tools - DIY Chatroom Home Improvement Forum
Old 07-02-2013, 09:25 PM   #1
Rewards Points: 85
I have a Home Depot BucketHead wet dry vac. I dropped it, and now it doesn't suck in anymore. It turns on and makes the normal vacuum noise, but no suction. It does still blow though. Anyone know what this might be? Thanks!
Chris
Chris Sweeney is offline   Reply With Quote
Old 07-02-2013, 10:07 PM   #2
Rewards Points: 6,652
Did you take it off the bucket to see if the ball is not locked against the opening inside? If the ball is not stuck, and still not working, take it back to HD and see if they will exchange with a new unit.
I have taken Circuit breakers back to our local Lowe's that I had on my workbench from when I did circuit change outs for our Kitchen, Bath and adding some Tandems. A few were overbuys, others had been used for maybe a month during changeout, and our local Menard's gave store credit for about a good $200 worth of breakers.
Old 07-03-2013, 09:31 AM   #3
Rewards Points: 13,300
Also check for any cracks or broken areas in the tank, cover not on right.
Old 07-04-2013, 05:11 PM   #4
Rewards Points: 85
You hit the nail on the head Joe. It turns out the top of the bucket was bent so the vacuum wasn't seating on the bucket properly. So simple!
Thanks again for all the responses!
The Following User Says Thank You to Chris Sweeney For This Useful Post:
gregzoll (07-04-2013)
Home Improvement Contractor Working Alone - Should I Get A Job? Chris Sweeney General DIY Discussions 16 06-19-2013 03:41 PM
Home Depot Commercial or not? kwikfishron Off Topic 3 11-05-2010 04:16 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
It took the Home Depot three roofs to get it correct! anewroof Roofing/Siding 10 11-27-2006 07:55 PM
