Hole Drill Bits For Cement Board - Tools - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 05:29 PM   #1
Rewards Points: 1,062
Question
hole drill bits for cement board
i was wondering if i can use the same hole drill bits for hardibacker as for wood.
Old 04-12-2011, 09:12 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Drilling cement board with a standard hole-saw bit will destroy it. They make hole-saws for drilling cement products.
Kyle
Drill bits for tile? jdraughn Tools 18 12-14-2009 10:30 AM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
w/t on masonry drill bits amakarevic Tools 11 03-11-2008 02:20 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 11:16 AM
