Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 09-20-2012, 12:24 AM   #1
Holding router bit while removing bearing screw
Works great and saves fingers/ bit. Rubber jaws.
Holding router bit while removing bearing screw-image-3526036514.jpg   Holding router bit while removing bearing screw-image-803597438.jpg   Holding router bit while removing bearing screw-image-1438750732.jpg
philmy is offline   Reply With Quote
The Following User Says Thank You to philmy For This Useful Post:
PaliBob (09-20-2012)
Old 09-20-2012, 07:22 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
you can also put the bit in the router and use a wrench on the collet so it doesnt turn
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
princelake (09-22-2012)
Removing a load bearing wall fitzy1 Building & Construction 13 04-22-2012 08:35 PM
Removing a headless screw - How to? Roxanne Akimbo Carpentry 6 03-12-2009 09:56 PM
removing a stripped screw (ROberston) square head wilsonfrench Carpentry 10 01-24-2009 05:34 PM
Question about removing a screw type fuse box... OmegaBunny Electrical 9 09-15-2008 11:13 PM
removing old basement tiles, no vis glue holding down?? mkarps Flooring 8 07-18-2008 11:33 AM
