Hitachi Nailer Problem - Tools - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 03:30 PM   #1
Rewards Points: 20
Hitachi nailer problem
I have a Hitachi NR83A nailer and about every 9 or 10 nails the piston will come out and leave a big dent in the wood but no nail. I think it is because the piston is not fully retracting after the last shot so it doesn't catch the head of the next nail. I give it a few drops of oil before each use and it has only gone through a few thousand nails in its lifetime. If this was just framing I wouldn't care so much but I'm building a fence and the big dent is noticeable.
Any idea why it is doing this?
Thanks.
Tubafore is offline   Reply With Quote
Old 04-11-2013, 05:50 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,354
what brand of nails are you using and what type. we have 3 of those guns at work and they do that if we use wire collated nails instead of paper. also what angle of nail are you using.. different guns will take different angled clips..
woodworkbykirk is online now   Reply With Quote
Old 04-11-2013, 07:49 PM   #3
Rewards Points: 20
I have been using Grip Rite plastic collated 21 deg nails. I think the same specs as the Hitachi branded nails.
Old 04-11-2013, 08:34 PM   #4
grip rite is the problem.. they use to be sold here and pretty much everyone using them had issues.. no matter what type of nail.. be it framer, roofer, or finish.. change brands
Old 04-11-2013, 08:53 PM   #5
Rewards Points: 20
I'll give another brand a try. Thanks.
Old 04-11-2013, 11:03 PM   #6
Also make sure the magazine is feeding well.
mbryan is offline   Reply With Quote
Old 04-12-2013, 05:03 AM   #7
i cant see the magazine being the issue. that model of hitachi gun is a tank.. the only other possible cause of the issue is using full head nails in a clipped head gun
Old 04-12-2013, 07:32 AM   #8
Have the NR83A2 and the top of the magazine got bent out a little, not sure how, and it would cause the nails to be bound up and not feed properly. Bent if back in and problem solved! Worth at least checking.
Old 04-14-2013, 04:35 PM   #9
Insatiable Learner
Rewards Points: 166
Smile
I use only Bostitch with my Hitachi nailer and have never had any issues with either
AngelArs is offline   Reply With Quote
American Standard intermittent inducer problem with presssure switch warning no such user HVAC 5 12-26-2011 05:20 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Bostitch N66C Nailer Problem mcqueary Tools 4 06-10-2008 11:57 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
