-   Tools (http://www.diychatroom.com/f29/)
-   -   Hitachi M12V Packing (http://www.diychatroom.com/f29/hitachi-m12v-packing-26/)
Unregistered 01-02-2004 03:17 PM
My new M12V was shipped in the fully down position. I have unlocked the plunge mechanism, and can not see any retaining clips/screws, but can not get the router to extend to the full up position.
Anyone had a similar problem?
Unregistered 01-02-2004 05:27 PM
I believe the M12 has 2 shaft locks doesn't it? I seem to remember reading this somewhere. And also check the double nuts on the threaded column - they may be threaded all the way down.
hatchet 01-02-2004 05:47 PM
That was me.. forgot to login. Can't you make it default to be logged in for posting messages?
Unregistered 01-02-2004 07:18 PM
Double nuts on threaded column are not binding, and plunge mechanism should be free to move.
The M12 has one shaft lock that I know of, a spring-loaded lock for bit changing. This is not the issue.
It has one plunge lock. The cam seems to release, but the router does not spring up.
hatchet 01-03-2004 12:25 AM
Huh.. doesn't that just frost your pants? Order a new tool and can't wait to get it and use it - and the thing doesn't work. I was mistaken on the 2 shaft locks also - just looked at the manual and they look like they are 2 wing nuts for something else.
Nathan 01-06-2004 01:59 PM
Yes, but then guests can't post without registering. I will change to this format soon but I'm leaving it open for now until things grow.
I will probably switching www.contractorschatroom.com over to this format soon.
GwB 04-10-2004 01:32 PM
Yes I have the same problem I got it loose posts are not square I think that is why it was under 200.00 On/off switch is dangerous easily bumped on. Idont think they will own up to the problem if not no more hitachi tools
