Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-24-2011, 04:11 PM   #1
Hitachi hammer drill going bad?
Well I got a hammer drill to do some tap con screwing, worked great! for the first 30 screws... then I started to have speed issues... right now if I push the trigger in a tiny bit it should rotate slowly, but no, full speed! it never did this until recently... it use to be variable speed, but now it wont go anything but max... is it gone? or can I take it apart and clean it or anything? didn't really want to have to buy another one.... thanks!
BlueBSH is offline   Reply With Quote
Old 06-24-2011, 08:54 PM   #2
Could be a bad trigger switch.......But most hammer drills that I've ever used have not been variable speed, are you sure yours was? If it was I'd take it back to the store........if it's used or past the return period I'm sure a trigger could be had for $20-$60
STL B. is offline   Reply With Quote
Old 06-24-2011, 08:57 PM   #3
yes, its a variable speed hammer drill
http://www.lowes.com/pd_194482-67702...rill&facetInfo=
that's the specific one I have right now, not top end but alright for a DIY user..
Old 09-13-2011, 12:15 AM   #4
I had a similar issue with an older model a few years back. The issue is with the "speed control dial" on the trigger. It was two years old and Hitachi fixed it same day at no cost for me.
You can look up replacement parts if it is out of warranty here:
http://www.toolpartsdirect.com/cgi-b...tachi/FDV16VB2
PartialHandyMan is offline   Reply With Quote
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 02:34 PM
Rotary Hammer Drill vs Hammer Drill jrepp44 Tools 6 06-29-2010 07:07 AM
rotary hammer drill ctkeebler Tools 8 04-10-2010 10:42 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 08:26 PM
