Hilti TE-60 Will Accept Non Hilti SDS Max Bits? - Tools - DIY Chatroom Home Improvement Forum
Old 06-14-2014, 08:22 PM   #1
Hilti TE-60 will accept non Hilti SDS Max bits?
Hello
Got a Hilti TE-60 ATC AVR Combihammer.
It is SDS Max and used the Hilti TE-Y bits
I assume I am not limited to HILTI SDS max bits and can use any brand's SDS Max bits ? Like Bosch or DeWalt etc...?
My owners manual says the :
Hilti TE 60 / TE-60-ATC uses TE-Y bits. TE-Y bits are "SDS Max"
and the Hilti TE 60T / TE 60T-ATC uses TE-T bits . The TE-T is also referred to as "SDS Top"
What is TE-T / SDS Top ?
Spud is offline   Reply With Quote
Old 06-14-2014, 08:35 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
hilti only wants people to use their bits.. simply to so more money goes in their pocket, if the chuck is has a standard 1/2" or 5/8 sds bit pattern and bosch, hitachi, or metabo bits will fit in it go for it. its not going to damage the tool
woodworkbykirk is offline   Reply With Quote
Old 06-14-2014, 09:20 PM   #3
The Hilti drill bit and Hilti pointy chisel I have for the TE-60 are 3/4 " diameter . The Chuck hole is also 3/4 diameter.
The Hilti drill bit I have says 5/8
Drill bits for porcelain tiles and granite miamicuse Tiling, ceramics, marble 8 06-17-2014 12:38 PM
SDS max vs. plus bits on SDS max drill jsunsun Tools 1 06-04-2014 10:11 AM
Tough Drill Bits miamicuse Carpentry 12 01-14-2012 06:40 PM
Auger bits last longer than spade bits? Ultrarunner2017 Electrical 36 01-31-2009 12:10 PM
