Hilti Rotary Hammer Drills - Tools - DIY Chatroom Home Improvement Forum
Old 06-26-2009, 01:51 AM   #1
vdu
Could someone shed something light on the difference between various Hilti TE 7X drill? The have the spec for TE 70, but not 72, 74, 75, 76.
Are the TE 72, 74, 75, 76 discontinued?
If not taken service into account, how similar spec Dewalt, Bosch, Milwaukee rotary hammer drill compared to Hilti? Let's assume Hilti is better, but would others be way behind, or just about 25% (example) behind in term of durability and performance?
vdu is offline   Reply With Quote
Old 06-26-2009, 06:35 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The Hilti 74,75, & 76 may be discontinued. The 74 is an SDS Max while the 72 is an SDS (different size bits) I could not justify it for me, but the nicest thing about the SDS Max is that they can use the spade bit for digging.
Hilti makes super quality tools but are expensive for a DIY'r. I have one of the Bosch tools and am very happy with it.
http://www.amazon.com/b?ie=UTF8&node=228261
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-29-2009, 03:48 PM   #3
vdu
If given a same price and age, should I buy a 72, 75 or 76?
It appears the 72 has 5" max concrete, 76 has 6", while the 75 only has 3. Is this true?
The 72 has a different look than all others, is it built for a different target users (such as professional contractors)?
Old 06-30-2009, 06:02 AM   #4
Tool Geek
PaliBob's Avatar
I really don't know Hilti except that they make very good commercial quality tools for heavy duty use. For occasional use for a DIY application the Hilti Max numbers are not as important. The Max numbers don't mean that the tool will never work past that point. It just means that the tool won't be as fast or last nearly as long as it would normally.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-30-2009, 08:48 AM   #5
General Contractor
What is your intended use for the drill? How often do you anticipate using it? Is renting more efficient than buying? You need to ask yourself these questions then choose a drill based on the answer. I use a Dewalt D-handle rotary drill (sorry don't know the model # and don't feel like digging through the trailer for it this morning) for 80% of my masonry drilling and/or demolition activity. The drill has a 1" bit capacity and will do light chipping as well. If I have to drill the occasional larger than 1" hole I simply use a smaller diameter bit and drill several smaller holes then knock out the center. If I have a lot of holes to drill like that or apearance is critical I will rent a larger more capable drill and run a coring bit. I have a smaller Makita for lighter situations which utilizes a 1/2" chuck instead of the SDS max. I use these for proffesional use and have had both for while now. If you are consitantly going to be drilling 3" to 4" holes through foundation walls with a coring bit or drilling and chipping concrete slabs on a regular basis the Hilti is the way to go. I have used Hilti in the past and they are comfortable to run especially for long periods. I don't think the average DIYer really needs to make that kind of investment but if you do more power to you and enjoy it.
ARI001 is offline   Reply With Quote
Old 06-30-2009, 10:40 AM   #6
vdu
You're right. However, I noticed that buying a good used powerful drill off Craigslist for example is very feasible. Not only that, the price between Hilti and others appear not that much difference. Also, I reason, a gas tank cost a lot of money. I asked my self why save $50, which is almost nothing these days, and not get a great tool. Sure, a lot of $50 will add up, but I don't often buy things like this at all. Renting a few times will be much more than the tool itself. Then, the bits themselves cost $60 new. So, I think the tool actually is the cheap one.
Another reason I want to go with Hilti, is that it's almost like a religion with this name. It seems they really produce great superior tools that no one I read says a bad things about it. I don't like fan boys, but I believe those are actual facts, not marketing machine from Hilti from my research. I hope that is the case.
Old 06-30-2009, 01:27 PM   #7
Tool Geek
PaliBob's Avatar
Originally Posted by vdu View Post
......Another reason I want to go with Hilti, is that it's almost like a religion with this name......
You're right on that point. I bought a Festool jig saw partly because I had other Festool gear and partly because of being overly optimistic as to the feature set associated with the NAME.
What happened was that I've never used the guide rail stop ($16 accessory) and have used the jigsaw very little compared to my Bosch barrel grip saw.
Another comparison would be when I bought a Porsche P'791. Well actually a Porsche design that is made by Metabo. It is really a high end drill that was a flop on the market because nobody wanted to take it to a job site because they thought it looked goofy.
I got a good deal on a close-out sale. It came with two chucks one for SDS plus bits and the second for regular drill bits. The only thing I wish for is that it would have come with a real Porsche to drive it around.
Hilti Rotary Hammer Drills-metabo-p7911-c.jpg   Hilti Rotary Hammer Drills-metabo-p7911-d.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
BOSCH SDS-MAX rotary hammer leaking oil profusely amakarevic Tools 4 08-21-2008 07:47 PM
please help select a rotary hammer amakarevic Building & Construction 9 07-04-2008 01:58 AM
did i fry my hammer drill's chuck ? amakarevic Tools 5 04-15-2008 02:48 PM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 08:26 PM
