Hilti Foam Can Confusion - Tools - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 11:49 PM   #1
Rewards Points: 1,062
Question
Hilti foam can confusion
european products are always so poorly documented...
well, i got a CF-DS 1 foam gun on eBay and the documentation that came with it nowhere specifies which can it's compatible with. so, naturally, i assume there is only one kind that comes with its own disposable nozzle but which is also compatible with the gun, which is what HD sells (CF 116).
well, it turns out that's wrong ...
even after extensive googling "hilti foam can does not fit gun" and variations thereof, nothing comes up.
brute force searching related links, i discover that there is a product called CF 812 and that's what fits on the gun... well, DUH, couldn't they be more specific in their instructions??
but here is the problem: i was trying to fit the 116 nozzle onto the gun and when i pressed, some foam went into the gun but the can didn't mount. my concern is whether that foam hardened inside the barrel and will i be able to use the gun again, i.e. is it destroyed? or can i just clean it with something or will it simply be OK without any repair?
thanks
Old 03-01-2012, 01:21 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
My experience with foam guns using pressurized foam insulation cans:
Foam Insulation Gun manufacturers typically offer a "cleaner" can (pressureized cleaning solution that disolves any foam residue within the gun's operating system) that is supposed to be connected to the insulation gun after any foam is sent through it.
If you don't properly clean out the gun, it will allow the foam insulation to harden-up in its operational mechanics, and will cause the gun not to function.
You could try and dismantle the gun and attempt to clean parts and replace other parts, however.....its usually a loss (if not cleaned with the canned-cleaner solution immediately after use).
- Build Well -
Old 03-01-2012, 03:46 PM   #3
their instruction booklet sucks, i blame the accident on it.
what also sucks is their customer service. i called them and they said the tool is more than likely toast and they wouldn't replace it. they couldn't really argue against my accusations for the suckiness of their manual. which is beyond terrible...
i'm gonna go to their specialty store in my area tomorrow, hoping to salvage it possibly and buy the cleaner as well as 812 cans (neither available at HD).
i will NEVER buy another one of their tools, maybe they are top-notch but not providing detailed instructions is downright arrogant in my book (because it assumes competence).
american and japanese tools are always far better documented. i also stop buying european cars for the same reason (poor or non-existing maintenance manuals).
Old 03-01-2012, 08:43 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,110
your sorely wrong about hilti, they make the best foam gun available on the market hands down. almost all of their gear is industrial grade and can out perform just about any tool sold at big box stores.
theres no science to loading a can of foam into a spray foam gun. with most hilti tools you have to use cans of foam that are clearly marked compatible with that model gun as they will not warrenty the tool if a cheap substitute was used as it can destroy the tool.. they do this with all their tools, i dont know how many time ive heard guys say their nail gun or powder actuated tool no longer works after using cheap nails or pins...
the tool didnt mess up you did sorry to break it to you
woodworkbykirk is online now   Reply With Quote
Old 03-01-2012, 08:47 PM   #5
it was not specified anywhere what type of can to use. they should have done a better job documenting. how am i supposed to know if they don't put it in the instructions?
nearly all european products are like this. american manufacturing has a better culture of documentation.
Old 03-02-2012, 04:27 PM   #6
It's ok. It's not toast
Tags
foam spray
Hybrid Spray/Rigid Foam Insulation yaemish Insulation 4 01-20-2012 11:55 PM
Vapor sealing with open cell foam insulation PerpetuallyRepairing Insulation 6 12-17-2011 09:16 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Replace Flange in basement with Foam? mattoxda Plumbing 1 10-10-2010 04:05 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
