Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-05-2005, 02:13 PM   #1
Exclamation
HELP!!! Ryobi 720 trmmmer problem
I have a Ryobi 720 trimmer, and the pull string came off track and is jammed. I am trying to get the housing apart to "unknot" the string, but can't get it aprat enough to do so. Can anybody help?
s-wilson is offline   Reply With Quote
Old 08-18-2007, 04:46 PM   #2
I know it has been two years, but here's how I did it.
The clutch assembly screws off the shaft (go CCW) but you have to lock the shaft from turning. I used the old screwdriver-between-the-plastic-housing-and-the cast-alum-fins-of-the-flywheel technique to jam the shaft from turning...and broke a fin in the process. Try inserting a bolt into the threaded end of the shaft and hold it with wrench while removing the clutch assembly. I removed the spring loaded clutch shoes and then used a pair of channel lock pliers to remove the clutch. After reassembling everything, the trimmer worked great.
WMcCaslin is offline   Reply With Quote
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
