-   Tools (http://www.diychatroom.com/f29/)
-   -   HELP!!! Ryobi 720 trmmmer problem (http://www.diychatroom.com/f29/help-ryobi-720-trmmmer-problem-683/)
s-wilson 06-05-2005 01:13 PM
:mad: I have a Ryobi 720 trimmer, and the pull string came off track and is jammed. I am trying to get the housing apart to "unknot" the string, but can't get it aprat enough to do so. Can anybody help?
WMcCaslin 08-18-2007 03:46 PM
I know it has been two years, but here's how I did it.
The clutch assembly screws off the shaft (go CCW) but you have to lock the shaft from turning. I used the old screwdriver-between-the-plastic-housing-and-the cast-alum-fins-of-the-flywheel technique to jam the shaft from turning...and broke a fin in the process. Try inserting a bolt into the threaded end of the shaft and hold it with wrench while removing the clutch assembly. I removed the spring loaded clutch shoes and then used a pair of channel lock pliers to remove the clutch. After reassembling everything, the trimmer worked great.
