Help My Battery Drill's Chuck Won't Hold The Bits - Tools - DIY Chatroom Home Improvement Forum
Old 06-08-2011, 05:21 PM   #1
help My battery drill's chuck won't hold the bits
Ok I've had it i'm up on a ladder drill in hand, drill two holes, put my drill into
my holster mark a spot reach for my drill and where is my bit ?
It fell out, The same happens with my screw bits ?
Now! i'm no Gorilla but I do put a good tight grip and tighten the chuck.
but after a few turns ooops there goes my bit.
So what experience have you had or better yet have you come up with a cure
for this problem.
ps this is no cheep drill.
roburt
robut is offline   Reply With Quote
Old 06-08-2011, 09:47 PM   #2
Not a Noob or Boob
Most nice cordless drills have a tightening feature on them. You simple chuck the bit holding the chuck in one hand and forward trigger till tight, then twist a few clicks and the bit should be nice and snug.
If you are still having an issue then you may need a new chuck. Sucks, but it happens on all drills no matter how much you pay.
Rob1975 is offline   Reply With Quote
The Following User Says Thank You to Rob1975 For This Useful Post:
robut (06-09-2011)
Old 06-27-2011, 09:53 AM   #3
Bit will not stay tight into chuck "solved "
Ok folk's I found the problem,
Dahhhh!!!
Read the manual 101, !! I have been gripping the chuck and turning on the drill,
after a few turns the bit would fall from the chuck. darn!!
Well the manual If I would have read it tells you " IN BLACK AND WHITE "
To grip the chuck and tighten by hand (( do not tighten by holding the chuck and turning on the drill )
So I did as the manual said.
I guess some people just don't slow down and {follow instructions }
Problem solved.
robut
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 05:40 PM
Bosch keyless, self locking chuck Bluwolf Tools 1 12-28-2009 06:40 AM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 05:34 PM
did i fry my hammer drill's chuck ? amakarevic Tools 5 04-15-2008 01:48 PM
