-   Tools (http://www.diychatroom.com/f29/)
-   -   help My battery drill's chuck won't hold the bits (http://www.diychatroom.com/f29/help-my-battery-drills-chuck-wont-hold-bits-107092/)
robut 06-08-2011 06:21 PM
Ok I've had it i'm up on a ladder drill in hand, drill two holes, put my drill into
my holster mark a spot reach for my drill and where is my bit ?
It fell out, The same happens with my screw bits ?
Now! i'm no Gorilla but I do put a good tight grip and tighten the chuck.
but after a few turns ooops there goes my bit.
So what experience have you had or better yet have you come up with a cure
for this problem. :censored:
ps this is no cheep drill.
roburt
Rob1975 06-08-2011 10:47 PM
Most nice cordless drills have a tightening feature on them. You simple chuck the bit holding the chuck in one hand and forward trigger till tight, then twist a few clicks and the bit should be nice and snug.
If you are still having an issue then you may need a new chuck. Sucks, but it happens on all drills no matter how much you pay.
robut 06-27-2011 10:53 AM
Bit will not stay tight into chuck "solved "
Ok folk's I found the problem,
Dahhhh!!!
Read the manual 101, !! I have been gripping the chuck and turning on the drill,
after a few turns the bit would fall from the chuck. darn!! :furious:
Well the manual If I would have read it tells you " IN BLACK AND WHITE " :yes:
To grip the chuck and tighten by hand (( do not tighten by holding the chuck and turning on the drill )
So I did as the manual said. :whistling2:
I guess some people just don't slow down and {follow instructions }
Problem solved. :thumbup:
robut :jester:
