Help With Impact And Ratchet Air Wrench Comparison, Confusing Specs Donít Match - Tools - DIY Chatroom Home Improvement Forum
Old 03-14-2009, 07:35 AM   #1
Rewards Points: 12
Help with Impact and Ratchet Air Wrench Comparison, Confusing Specs donít match
I am trying to compare two tools: Kobalt Impact Wrench and Craftsman Impact Wrench. I need help understanding why one is better over the other.
Kobalt .................................................. ............................Craftsman
Air Pressure 90psi .................................................. ..........Max Air Pressure 90psi
Ave Air consumption 4 CFM ............................................Ave Air Consumption 4.4 SCFM
Max Torque 360 ft. lbs .................................................. ...Max Torque 300 ft lbs
Free speed 7000 rpm +/- 10%.......................................... Free Speed 7500 rpm
Frustrating thing is one is measured in CFM and the other is SCFM. Max torque tells me to go with the Kobalt but the Ave Air Consumption on the Craftsman is higher, but again the units aren’t the same CFM vs SCFM
The other tool is the Ratchet Air Wrench
Kobalt .................................................. .............................Craftsman
Air Pressure 90psi .................................................. ............Max Air Pressure 90psi
Ave Air consumption 3.5 CFM ...........................................Ave Air Consumption 4.9 SCFM
Max Torque 60 ft. lbs .................................................. .......Max Torque 45 ft lbs
Free speed 160 rpm +/- 10%.............................................. Free Speed 150 rpm
Here again torque much better on Kobalt but Ave Air Consumption on the Craftsman is higher, was thinking that ave air consumption meant it was more powerful. Don’t know, very confused. Please help.
caliskier is offline   Reply With Quote
Old 03-14-2009, 03:13 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
For your purposes SCFM and CFM would mean the same thing. Everything else being relatively equal, I would go with the higher torque models.
Old 03-14-2009, 03:38 PM   #3
Rewards Points: 12
Thanks so the ones with the higher SCFM do not necessarily mean better performance?
Old 03-14-2009, 06:17 PM   #4
Rewards Points: 20
CFM is the measurement of air it takes to make the torque. One tool might be more efficient so it creates more torque with less air consumption. Kinda like saying one car can go farther than another on less gas.
ponch37300 is offline   Reply With Quote
Old 03-14-2009, 08:06 PM   #5
Rewards Points: 12
Thanks guys, air tools are very confusing
Old 03-15-2009, 10:33 PM   #6
You want to get air tool experts then visit
www.garagejournal.com
JayL is offline   Reply With Quote
