Help Choosing A Drain Cleaning Machine? - Tools - DIY Chatroom Home Improvement Forum
Old 07-23-2009, 05:28 PM   #1
Rewards Points: 682
Help choosing a drain cleaning machine?
I am looking to get a powered snake for old drainage systems.
I've read that a 1/2 hp is good for pipes up to 4" and a 1/8 hp is good for pipes 33/4" to 2.5", is this true?
Does the thickness of the snake matter? They all seem the same size.
Are there any good brand names?
darsunt is offline   Reply With Quote
Old 07-23-2009, 08:06 PM   #2
Thickness of the snake is generally determined by pipe diameter. The hook and coil on the end needs to be large enough not to turn back at you so it's length will increase with pipe diameter... and a heavier longer coil will need a heavier motor.
Not sure about power drives but the OLD RIGID pipe equipment, all metal was good stuff
Chemist1961 is offline   Reply With Quote
Old 07-30-2009, 05:36 PM   #3
motivator
Speedball's Avatar
Rigid brand and General are sold locally here and I have used Spartan for a few years with good luck.
............Enjoy...Pat
Speedball is offline   Reply With Quote
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 08:08 PM
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 08:16 AM
Washing Machine Drain mqcarpenter Plumbing 3 11-20-2008 08:47 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 08:24 PM
