Help With Campbell Hausfeld 8 Gal Wall Mount Air Compressor-won't Start - Tools - DIY Chatroom Home Improvement Forum
Old 05-05-2014, 08:12 AM   #1
Rewards Points: 14
Help with Campbell Hausfeld 8 gal wall mount air compressor-won't start
I have a CH 8gal wall mount that won't start. It has power as the power button illuminates when I turn it on but the compressor won't turn on. I started it yesterday (successfully), went into the house for something and when I went back out to the garage, gauge read 40psi, but it was not running when I got out there. Any suggestions? I don't want to buy a new one as I love the wall mount and just use it for general light duty projects around the house.
If i do need a new one, does anyone know of any similar new ones that are wall mount? I know this one is discontinued.
Thanks for your help.
Lvkopike is offline   Reply With Quote
Old 05-05-2014, 08:15 AM   #2
Rewards Points: 14
I was going to post pics of my model. But I don't have enough posts to do so.
Old 05-05-2014, 08:16 AM   #3
Rewards Points: 14
Also, as I can't edit posts on here, I wanted to mention that I unplugged it and plugged it in again multiple times to no avail.
Old 05-05-2014, 08:16 AM   #4
DIY staff
Rewards Points: 7,174
What have you done so far?
Did you let the pressure out of the tank?
Checked the power at the regulator?
Checked to see if there is a reset button on the motor?
Pressed the regulator with an insulated stick and see if the regulator is working?
Tell us more---------
Old 05-05-2014, 08:21 AM   #5
Rewards Points: 13,978
Just post the model #.
Old 05-05-2014, 09:00 AM   #6
Rewards Points: 14
I relieved the pressure.
Please forgive my ignorance, but how do I check power at regulator? Would the reset button on motor be beneath the plastic cover below the tank or would there be an access hole?
Old 05-05-2014, 09:02 AM   #7
Rewards Points: 14
Model # is WL675000
Old 05-05-2014, 09:09 AM   #8
http://www.mastertoolrepair.com/camp...0-p-24909.html
Old 05-05-2014, 09:11 AM   #9
Just Google "wall mounted compressors, lots of them come up.
If I was replacing it I'd go for a simple pancake style compressor so I could use it anyplace.
Old 05-05-2014, 04:23 PM   #10
Rewards Points: 14
Thanks for your help guys. It has to be the pressure switch, so I ripped it apart and ordered a new one.
Old 05-05-2014, 04:24 PM   #11
Rewards Points: 14
The Following User Says Thank You to Lvkopike For This Useful Post:
oh'mike (05-05-2014)
Old 05-12-2014, 09:08 PM   #12
Rewards Points: 14
It's alive! It was the pressure switch.
wall mount bath faucet rough in DIYMario Plumbing 4 05-28-2013 08:50 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
How to mount wall cabinet spaced out from the wall ten inches? mystic_cobra Carpentry 10 11-17-2011 11:17 AM
Campbell hausfeld air compressor wont start Steve12 Tools 25 03-04-2011 08:17 PM
Installing wall mount rack on a concrete wall? helpless handyman Building & Construction 5 08-20-2010 09:33 PM
