Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-09-2008, 11:58 AM   #1
Help With Buying A Compound Mitre Saw
I was thinking of getting a basic type compound mitre saw. I'm not a heavy duty diy'er so it would just be for smaller projects here and there. Sears has a couple of Craftsman models on sale for $89 and $99.
http://www.sears.com/shc/s/s_10153_1...&sbv=Craftsman
I was just wondering whats the reason fro the size difference, 7 1/4" vs. 10" ? Why I would need one over the other.
jte1130 is offline   Reply With Quote
Old 12-09-2008, 12:19 PM   #2
The 10" allows for more cutting capacity. I have the 7 1/4" and I really like it. I also have a 12" sliding which is a beast to move around. If you are only going to have one saw, I think I would get the 10" for the increased flexibility. It's still small enough to handle easily and it will allow you miter cut 2X4's.
jerryh3 is offline   Reply With Quote
Old 12-09-2008, 02:29 PM   #3
Thanks. So I take it the 7 1/4" can't cut 2x4's?
Old 12-09-2008, 03:06 PM   #4
It can, but I think only at 90 degrees.
Old 12-09-2008, 04:45 PM   #5
bradnailer's Avatar
I'd definitely go with a 10" saw.
bradnailer is offline   Reply With Quote
Old 12-10-2008, 03:00 PM   #6
Finish Carpentry Pro
I use a 12" slider for cutting wood trim for work, but the company needed something smaller and cheaper for some aluminum trim that we needed to cut and install on some wood panels
We picked up a Skil 10" miter saw. It is really a great little saw; similar to the Bosch miter saws, because they are owned buy the same company. You might want to check them out at Lowes. I don't HD has them
Quiglag is offline   Reply With Quote
spackle versus joint compound... joeyboy General Discussion 11 02-26-2011 08:51 AM
Compound Mitre Saw fengler19 Tools 9 08-02-2008 01:18 PM
10" sliding compound mitre saw curls00 Tools 7 08-16-2007 08:18 PM
12" Sliding Compound Mitre Saw jr66 Tools 7 05-28-2007 05:12 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
