Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 08-13-2010, 06:42 PM   #1
help buying air compressor
I am in the market for an electric portable compressor to run one framing gun, not production speed (and to blow up tires etc in future). Also, it will plugged in to about 200' of 12 gauge extension cord... what size tank? horsepower? It sounds like oil is better than oil-free and can be fixed? I don't want to spend more than I have to,.....looking at used.Thanks
ugabulldog is offline   Reply With Quote
Old 08-14-2010, 07:51 AM   #2
Super Moderator
That 200 foot of cord might kill the compressor -----Longer air lines and a shorter (or no) extension cord
would be best.
As to the cfm requirements---some one will give you that---Mike--
Old 08-28-2010, 12:54 PM   #3
Wire Chewer
Red Squirrel's Avatar
If you use 12 awg you should be ok I would think. Plug the cord in and test the voltage at the other end to see how much of a drop you get while the compressor (or another big enough load) is running.
buying a nail gun with compressor Dave777 Tools 9 11-28-2011 12:37 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
Please help: blown fuse, slow compressor fan, and hissing noise from compressor frazwr01 HVAC 10 06-27-2010 10:08 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
