#1 |
Help with broken drill
I have a drill that I was using fine for many years until now. The problem is that the mouth of the drill won't close so I obviously put a drill bit in because it won't stay in. Whenever I try to close it, it makes this weird noise but won't budge. It will rotate but the end will not close around the drill bit. Can anyone tell me what to do??
#2 |
If it's an expensive drill worth repairing, replace the chuck if you can find a replacement for it.
There's usually a screw in the chuck that you remove. Depending on the model, sometimes the chuck will slide out but usually you have to unscrew them using an large allen wrench. You'll probably have to give the allen wrench a good wack with a hammer to break it loose. Once removed, replace it with a new chuck. However, if your chuck won't open or close, you might have trouble getting to the screw or unscrewing the chuck from the drill. |
#3 | |
Help with broken drillQuote:
| Tags |
drill bit fix it ![]() |
| Display Modes | |
| Broken drill bit in expensive tiles. Oops. | manuelhung | General Discussion | 8 | 05-17-2008 02:35 AM |
| Broken Drill Bit . . . | chins01 | Remodeling | 4 | 01-25-2008 12:38 AM |
| Broken Drill Bit | Freelancer | General Discussion | 15 | 03-29-2007 05:01 PM |
