Has Anyone Ever Tried To Make A Table Saw Top - Like The Rousseau "PortaMax Jr 2600? - Tools - DIY Chatroom Home Improvement Forum
Old 04-30-2013, 12:03 PM   #1
DIY Padawan
CaptainMarvel's Avatar
Question
Has Anyone Ever Tried To Make a Table Saw Top - like the Rousseau "PortaMax Jr 2600?
Just curious if any of the ingenious innovators here have ever tried (and/or succeeded) in creating a "replacement" top for their portable table saw - similar, perhaps, to the Rousseau PortaMax Jr 2600 (links + image below).
I inquired about the construction of the product from Rousseau, and this is the response I received . . . *
"The table top of the 2600 is a particle board with high pressure laminate on both sides and edge banded. The frame of the 2600 surrounds the top of the saw and bolts to the saw. Thus the 2600 stays with the saw and utilizes the top of the saw and the laminate top of the 2600 to expand rip capacity."
http://www.rousseauco.com/model2600.htm
http://www.amazon.com/Rousseau-Porta.../dp/B0000224RS
I am consistently amazed and inspired at the sheer creativity and innovation that I see amongst so many contributors here that I thought I would pose my question here ... thinking, perhaps, there might even be ideas as to how to improve upon the "rousseau" idea - as a DIY project.
Looking forward to (hopefully) some inspiring insight, ideas, thoughts, etc.
THANK YOU !!! . . .
TOM
CaptainMarvel is offline   Reply With Quote
Old 05-02-2013, 01:15 PM   #2
DIY Padawan
no thoughts whatsoever ???
Old 04-30-2017, 02:00 PM   #3
Rewards Points: 2
Re: Has Anyone Ever Tried To Make a Table Saw Top - like the Rousseau "PortaMax Jr 26
I've tried and was not satisfied.
Andrew41 is offline   Reply With Quote
Old 04-30-2017, 02:57 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,790
Captain.... Interesting... (although I've got a 25" rip capacity)...
Wouldn't the real trick being in getting acurate / fitting / and sturdy rail system.
Many years ago I had built some outfeed and side tables... but the saw was still independent of them... as I recall, I did just use standard melamine sheets.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-01-2017, 02:40 AM   #5
jlhaslip's Avatar
Rewards Points: 2,882
Closest I have come to this is building a side extension table on an old Rockwell Beaver 9 inch table saw. A friend was getting rid of his long rails, so I added them to my saw and filled in the extension using a laminate covered piece of plywood. All 6 faces were laminated. Worked okay.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 05-22-2017, 09:37 PM   #6
Flannel Guy DIY
Flannel Guy DIY's Avatar
Rewards Points: 190
Not portable, but I put this video together showing how you can integrate your table saw into a much larger work surface. Basically the saw is built into the workbench.
How To DIY Videos YOUTUBE - Giving away free tools to subscribers!
Flannel Guy DIY is offline   Reply With Quote
Super glaze bar table finish jlwiu1 General DIY Discussions 18 02-05-2016 03:52 PM
Reclaimed wood console table thedecoratorinme Building & Construction 4 03-27-2011 12:21 AM
Proper wiring for an electric motor from the breaker box (for an air compressor) capslock Electrical 22 12-22-2009 02:12 PM
ideas on how to make a fold down work table kimber Carpentry 2 10-08-2009 11:56 AM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
