Hammer Drill Spits Sparks - Tools - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 10:36 PM   #1
Registered User
Termite's Avatar
Hammer drill spits sparks
I have a Ridgid 1/2" hammer drill....The big model with a cord. It was new two years ago and has seen very little use. The other day I was drilling holes in my foundation for some tapcon screws and had the drill in the slower of the two gear speed settings as well as in hammer mode. It was getting it done but slowly, so I set it into the faster of the two speeds. I was surprised to see lots of sparks coming out of the vent holes that surround the motor. I mean the sparks were coming out 2-3"!!!
I'm going to take it back or at least call Ridgid to see what their lifetime warranty will do for me, but does anybody have any idea what would cause this? It hasn't had more than a total of 15 or 20 minutes' use in the two years I've owned it so I can't imagine it is worn brushes if it even has brushes.
Old 03-16-2010, 08:16 AM   #2
Remodeling Contractor
it's a Rigid is the main reason. Most likely you stored it in a unconditioned room or an area using an unvented heat source. Therefore moisture accumulated on the brushes. Replace the brushes and you should be fine.
Old 03-16-2010, 02:29 PM   #3
Registered User
Termite's Avatar
Dang Bob, you're psychic! I did store it in my unconditioned garage. Shame on me!
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Is my new hammer drill broken? darsunt Tools 13 09-16-2009 09:53 PM
hammer drill vs. drill/driver wombosi Tools 10 05-12-2008 09:40 AM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
