Hammer Drill Necessary? - Tools - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 03:12 PM   #1
Hammer drill necessary?
Hey all..I will be doing a basement remodel soon which will require securing subfloor/wall frame to concrete floor (and concrete block wall). Will a hammer drill be necessary? About to buy a new drill and trying to figure out what i will need.
markley is offline   Reply With Quote
Old 03-16-2012, 03:19 PM   #2
Rewards Points: 582
Get an SDS one.
stuart45 is offline   Reply With Quote
Old 03-16-2012, 03:30 PM   #3
Too Short? Cut it Again!
Concrete nails, ramset gun (for fasteners into the floor, not the block), etc. There are lots of alternatives. You will probably find many uses for a combination hammer type drill though and be pleased long terms with your purchase. It will certainly make drilling into concrete a lot easier assuming you have decent bits suitable for the hammer action.
Old 03-16-2012, 04:12 PM   #4
Rewards Points: 512
dricore the floor
princelake is offline   Reply With Quote
Old 03-16-2012, 05:34 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
For the average DIYer, the most cost-efficient way to go is a combo "Drill/Hammer-Drill". You will get more long-term, multiple-use, out of the tool.
A rotary hammer and even an SDS model are more speicalized and will do the work much easier, but will cost significantly more than a combo hammer-drill. As a DIYer, you may also never use the tool again, or very, very little.
The other option is to rent.
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
PaliBob (03-18-2012)
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 01:34 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 09:08 PM
Rotary Hammer Drill vs Hammer Drill jrepp44 Tools 6 06-29-2010 06:07 AM
rotary hammer drill ctkeebler Tools 8 04-10-2010 09:42 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
