Hammer Drill Feature With Regular DD - Tools - DIY Chatroom Home Improvement Forum
Old 05-16-2016, 04:40 PM   #1
Rewards Points: 141
Hammer drill feature with regular DD
All I need to do is drill a few holes in brick, concrete, limestone and hardwood flooring. Do I need a drill with a hammer drill setting? Or can I do these holes with a regular drill with say, 500 in-lbs of torque?
RocketGal is offline   Reply With Quote
Old 05-16-2016, 06:30 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Re: Hammer drill feature with regular DD
Nope, the bit will be burnt up before ya do the 1st hole,.....
Hardwood floorin' is no problem, no hammer needed,...
I bought myself a hammer/ regular drill, 'n gave my ole lady the regular drill I had,...
Bondo is online now   Reply With Quote
Old 05-17-2016, 09:36 PM   #3
Rewards Points: 297
I'm not so sure. I've drilled a few masonry holes before I acquired a hammer drill around a decade ago. Brick can usually be drilled with just a rotary action. I've never drilled limestone, but I would guess it is soft enough to can be drilled similarly. Concrete can vary a lot in hardness. Before I had a hammer drill, I've encountered concrete which was relatively easy to drill, and concrete which was a royal pain to drill without a hammer drill. Hammer action sure is nice if you have it though.
If you currently have a non-hammer drill, and only have a few small holes, there is no harm is giving it a try. Hammer drills have become much more popular, if you only have a few holes you might see if you can borrow one as well. (Even though I have two hammer drills now, I borrow a Hilti rotary hammer if I have drill any real holes in concrete.)
LanterDan is offline   Reply With Quote
Old 05-18-2016, 08:25 PM   #4
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
If you already have a regular drill, it may only cost a bit to find out. If you're going to buy one, just get a hammer drill. They aren't that much more than a regular one.
I hate signatures.
Mort is offline   Reply With Quote
Old 05-18-2016, 09:27 PM   #5
ZZZZZ's Avatar
Rewards Points: 2,206
Regular or hammer drill, either way you need a good masonry drill bit. A regular wood or metal drilling bit will not cut it - literally.
ZZZZZ is offline   Reply With Quote
Report: Hitachi Brushless Hammer Drill & Impact Driver Combo More Power! Tools 0 07-27-2014 09:28 AM
Milwaukee cordless hammer drill - keyless chuck screw stripped eclark Tools 5 09-11-2012 11:46 AM
Milwaukee M18 Combo kit w/ Hammer Drill MooseWoodworks Tools 16 12-24-2011 01:22 PM
Debating a Hammer Drill mikeylikesit580 Tools 16 01-31-2011 01:50 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
