-   Tools (http://www.diychatroom.com/f29/)
-   -   Guidance on Buying a MultiTool (http://www.diychatroom.com/f29/guidance-buying-multitool-166233/)
RichardZ 12-11-2012 04:25 PM
It's been recommended that I get a multi-tool for a particular project I'm working on, so I'm breaking down and buying one.
I'll probably use it off and on to do various projects, so I want to get a decent one, but it doesn't have to be top-of-the-line.
I'm thinking corded, as I'll probably be near an electrical outlet whenever I use it, and I'd like the extra power. Anything else I should consider?
In terms of brands, someone said that they had a Craftsman, and it had worked well for them for a few years.
Another recommended Fein, which seems pricey but gets good reviews, and I think I can get a starter kit that will only cost an arm.
Others I'm looking at are Porter-Cable, Rigid, and Dremel. I'm a little leery of Dremel because of its hobbyist roots, but they seem to be moving to meet more robust demands and might be OK. Rigid has a lifetime guarantee, and a free attachment until 12/26, so that's attractive. And Porter-Cable seems to just make good tools.
Any feedback on any of the above? Anything else I should consider?
Your help is greatly appreciated!
Richard
joecaption 12-11-2012 04:36 PM
Needs to be moved to tools.
jmd87 12-11-2012 04:38 PM
It seems like you have a "multi-tool" in mind... can you post a link or something? Saying "mulit-tool" isn't like saying "table-saw", it's like saying "cutting tool"... a little broad.
What project are you intending to work on? This would help with the feedback.
joecaption 12-11-2012 04:47 PM
I own two of the Rockwell Multi Crafters and love them.
If I was in the market for another on I might try the Ridgid. Reasons being as you stated, long warrenty, now offered with the ablity to just snap on differant heads for differant jobs.
My impact driver and ossilating tool are two of my main go to tools.
Take the Dremal right off of your list, your right it's little more then a toy.
Your going to find the blades for any of the ossilating tools way over priced.
I found a company on Amazon.com that sells the blades for about 1/3 if you buy 15 at a time.
ToolSeeker 12-11-2012 04:47 PM
I have a rockwell and am not really crazy about it. I don't have one but I have been looking at the Ridgid just for the fact of the different heads (7 I think) that you can get to fit it. This I feel would make it An even more versatile tool.
kwikfishron 12-11-2012 05:21 PM
199 Attachment(s)
Bought the Dermel one because I thought I needed it that day and that was the only quick choice at that moment. The thing is junk imo. Seems more like a toy than a tool.
beenthere 12-11-2012 05:53 PM
Moved to tools forum.
oh'mike 12-11-2012 05:58 PM
I bought a Harbor Freight one--the better of the two that they sell----$40 on sale---
Darn tough tool--I recommend it---Blades ar cheaper than other brands,too.
I use it for---tile squeeze up---cutting hard old caulk--PVC pipe--undercutting trim--and more
woodworkbykirk 12-11-2012 06:24 PM
the dremel is a toy for a reason.. plastic gears and thin low gauge wiring..
the porter cable is the exact same tool as the black and decker along with the stanley fatmax.. all made by the same company not to mention since pc quality went out the window 6 years ago when black and decker bought them out
i own the cordless ridgid and the corded bosch multix 2.5 the bosch is the only competition for the fein who originated the tool then the patent ran out so almost everyone makes them. my bosch is a beast it cuts faster than the new dewalt 12v recip saws. with the rigid ive had 3 batteries go stale in a short life span, i was expecting far more charge cycles before they died considering its lith ion.. though rigid tools are known for this along with milwuakee who are from teh same parent company.. also the rigids are really bad for the sawdor on the trigger going bad early on. .both the local home depots and the rigid repair centre have seen a ton of them come back with this problem
if i were to buy another one id be getting hte bosch again or the makita, two companies that are known for putting out quality not quantity of tools
kwikfishron 12-11-2012 07:14 PM
199 Attachment(s)
Plastic gears and thin wire mean "burn up fast" to me. Never got that far, for a hundred bucks I was hoping it would at least pretend to be a tool, for a little while anyway. :wink:
I bought it because I thought it would be perfect for ultra fine tuning of exposed notches (after chain saw and Sawzall) on a log cabin I built last winter. What a joke, back to a sharp chisel.
I have ZERO patience for tools that donít perform and will gladly pay twice the price (or more) to not deal with junk, just wasn't in the cards that day.
Just my experience with that one tool.
jeffsw6 12-11-2012 07:18 PM
I like my dremel tool but I don't use it for crazy things. I don't see it as a substitute for a drum sander or a cutting wheel like they seem to encourage on the TV commercials! It's a small tool for detail work.
Some people do not know that Dremel makes several different rotary tools. The one I own cost about $100 (with some accessories) and it is clearly a bit better than the $30 one. I'd guess if you had driven F350s and 3500HDs but the only Dodge you ever drove was a Dart, you probably wouldn't have a favorable opinion of Dodge, either! :)
itguy08 12-12-2012 08:05 AM
I've got the Milwaukee M12 Cordless one and it works very well but has short battery life. If you can live with that you should be good with it. For corded I've heard good things about the Harbor Freight units - can't beat the cost if you're not using it day in and day out.
Interesting - Dremel is owned by Bosch and B&D/PC/Stanley/Dewalt is Black and Decker so I'd have thought they would not source from the same factories...
msaeger 12-12-2012 11:47 AM
I would check out what the blades cost and what ones they have where you are.
I got a fein and it's great and the cheaper 3rd party blades I can get at menards fit it.
woodworkbykirk 12-12-2012 03:23 PM
kwik im the same way.. 99% of my tools are high quality.. the 1% of low grade tools are things that i might use once every two years.. i have a super cheapy rotary tool thats store brand. bought it solely for messing around with carving and for tuning up coped joints.. when im on commercial jobs ive used it for reaming out holes for peep holes in doors because the actual unit doesnt have a drill bit size that matches it so i have to use the closest bit size smaller then grind it out a touch for it to fit.. next bit size up is too big
bpm 12-14-2012 09:38 AM
I have the Bosch corded and highly recommend it. The Fein seems to be the best out there, but is very pricey. I've also used the Dremel and probably would have it thrown it in the trash if it belonged to me. It was very hot to hold and I could still feel the vibration in my hand for an hour afterwards.
