Ground Anchor Winch Madehome - Tools - DIY Chatroom Home Improvement Forum
Old 04-04-2014, 04:11 AM   #1
catrico's Avatar
Rewards Points: 14
ground anchor winch madehome
hello I do not know if they are in the right forum, however, expose the problem for the winch of a land rover defender we need to achieve an even Terrestra homemade you can help thanks
traduzione
salve non so se sono nel forum giusto comunque espongo il problema per il verricello di un land rover defender ci occorre realizzare una ancora terrestra fatta in casa potete aiutarci grazie
http://i268.photobucket.com/albums/j...0/IMG_4870.jpg
http://www.keepandshare.com/userpics...?ts=1349054977
https://lh6.googleusercontent.com/-4...2520anchor.jpg
catrico is offline   Reply With Quote
Old 04-04-2014, 09:07 AM   #2
Rewards Points: 13,256
Not even sure what it is your asking.
If your trying to make you own your going to need a welder, band saw, some square tubing and a piece of flat plate, and a screw pin shakle.
In my area there lots of boating consignment shops I'd just pickup a used Fluke type anchor.
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 10:51 AM
Subpanel - equipment ground feed wire not terminated peaks Electrical 2 12-27-2012 05:37 PM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
