Going To Buy A Table Saw Tomorrow - Tools - Page 5 - DIY Chatroom Home Improvement Forum
Old 01-15-2014, 10:24 PM   #61
Rewards Points: 590
Just checked and its at $299 still around here. Wonder what's up with that.... I paid $269
nikeman is offline   Reply With Quote
Old 01-16-2014, 02:51 PM   #62
Rewards Points: 267
They may be clearing it out. They seem to have a new product, the 7480
http://dewalt.com/tools/machinery-po...s-dwe7480.aspx
It's probably a replacement. The main difference seems to be it can rip to 24" so unlike the 745 you can split a piece of plywood down the middle, which may have been seen as a major competitive product problem for the 745. One negative of the new saw seems to be it won't accept dado blades. Seems a bit odd to design a new product seemingly to address some competitive weaknesses and leave this out. HD price is at $369, which - as I recall so I may be wrong - was about what the old saw used to cost.
Seems like a smart move. One of the reasons I went with the Bosch 4100 was for the fence rip capacity. Usually I'll still have those big cuts done right at the store and then smaller cuts at home, but I wanted it anyway just in case. Except for the dado issue - maybe not important to some - the saw now seems more feature competitive with some more expensive products.
Scottg is offline   Reply With Quote
Old 01-16-2014, 03:47 PM   #63
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
The older Dewalt, DW745. isn't supposed to be used with dado blades either. It's the only reason that saw didn't come home with me last night.
hyunelan2 is offline   Reply With Quote
Old 01-16-2014, 05:52 PM   #64
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
I don't think you can use a dado with any of the portable saws, I may be wrong. I would think if any portable saw did it would be the Bosch 4100 but that saw weighs 124 pounds, the DW745 weighs about 48 pounds, not that the weight has to do with anything. I was just thinking there is no way I could handle a saw that weighed 124 pounds now days. I hate that Bosch is made in Taiwan now days.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-16-2014, 09:30 PM   #65
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,264
the bosch is 124 lbs when its mounted to a gravity rise stand.. the dewalt saw that mounts to their rolling stand is quite a bit more than 48 lbs.. we have two of them at work. the majority of the guys on our crew cant lift it by themselves
woodworkbykirk is offline   Reply With Quote
Old 01-16-2014, 09:55 PM   #66
Rewards Points: 590
Seems like all they did was add 4" of rip capacity on this saw. Mine has 20" plus it actually goes another inch or so past the 20" point on the ruler.
Old 01-16-2014, 10:07 PM   #67
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
Thanks for clearing that up Kirk, that makes sense. My nephew had a DW774, I think, (it was one of the first portable table saw DeWalt made in the yellow plastic) but he had the light fold up stand and I know that saw wasn't that heavy.
I want to sell my Unisaw and buy one of the DeWalt saws, the Unisaw takes up way too much room in my shop.
Jim
Old 01-16-2014, 10:16 PM   #68
hyunelan2's Avatar
Rewards Points: 692
The lightweight (52 lbs) bosch gts1031 is dado compatible. It is only an 18" rip though.
The Following User Says Thank You to hyunelan2 For This Useful Post:
BigJim (01-19-2014)
Old 01-19-2014, 05:13 PM   #69
Rewards Points: 267
As both Big Jim and Kirk mention above, the Bosch 4100-09 on the stand is 124 lbs. But the 4100 saw alone should be about 60 lbs alone if that's how you'd use it.
Anyway, since dados have come up, the 4100 does take dado blades. I've not done it myself, but I've just checked my manual and it does have instructions for stacked dado sets to be used. In addition to - or included in the blade kit, you would need some kind of Dado Accessory Kit that has an accessory washer, and then you'd want a special Dado Table Insert. I haven't shopped for it, but I'd think their own blade kit would have this, but if you were to go with this saw and get another brand dado set, you'd want to make sure about that additional accessory washer being included or getting it separately. Bosch has a dado insert plate as well, but I'd probably get one from Lee, same as the zero clearance insert I got from them for my regular blade.
Old 01-20-2014, 12:02 AM   #70
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
In my 42 years of wood working I owned two dados, one a stack and the other a wobble set. I probably used them maybe two or three times all that time. I did see the results of a dado stack that came loose, talk about a mess. I find the router is much easier and quicker to set up and use than a dado and it is a neater results. JMHO
Jim
Old 01-20-2014, 02:22 PM   #71
the bosch 4000, 4100 and the gt10 all can accept a dado blade as the throat plate is the exact same on all three models from what i recollect.. you can order the part on amazon pretty easily or any tool store that does custom orders
regarding the weight thing i prefer the saws that you can dismount the saw from the stand easily.. i have the bosch 4000 and the old folding stand.. its much easier to move around that way. the dewalt saws are a pain in the ass to try to unmount from the rolling stand
The Following User Says Thank You to woodworkbykirk For This Useful Post:
BigJim (01-20-2014)
DIY Table Saw vs Ready-Made Table Saw ?? CaptainMarvel Tools 19 01-15-2013 07:21 AM
10" table saw or compound mitre saw - which would you choose? whataboutj Tools 9 12-03-2011 03:13 PM
Tressle table - how to build? Knucklez Carpentry 1 10-24-2009 03:18 PM
Need Advice for Adding Wheels to Table HandyDottie Carpentry 7 01-27-2008 07:44 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
