Glazing? Lapping? - Tools - DIY Chatroom Home Improvement Forum
Old 12-01-2014, 03:50 PM   #1
Rewards Points: 120
Glazing? Lapping?
I was jokingly thinking that it was probably 40-50 years ago, until I realized that it really was that far back, that I remember my dad showing me how to put a neat swirl affect on something metal, can't remember what now, using a dowel in a drill chuck. The finish looked about like you see on the bolt of some rifles for anyone that makes sense to. My memory tells me that he referred to it as glazing compound, but I'm not seeing anything on the internet that clicks. It was in a small tub, similar to axle grease, and was a paste with a very fine grit. And I guess that it may have been valve lapping compound, but that was obviously common at that time, and I am pretty sure I would have remembered that, so am thinking that this was something different. Anyway, wondering if anyone knows what the heck I am thinking of.
Old 12-01-2014, 04:27 PM   #2
MarginallyQualified
Rewards Points: 2,464
Valve lapping -engines
Old 12-01-2014, 04:47 PM   #3
(the original)
Rewards Points: 756
Loctite Clover, maybe?
ratherbefishin' is offline   Reply With Quote
Old 12-01-2014, 05:08 PM   #4
Rewards Points: 120
Tarheel, it could be valve lapping compound, and it was similar in nature, so I will probably run a few tests with it. But, as I mentioned, that was fairly common at that time, in fact I pretty much assumed that every dad could overhaul an engine, or at least a neighbor could, because things were, well, different then, and I'm thinking that this was something more unique. RBF (I like that name by the way), it looks like they have a variety of products, so will read through them and see what the local Grainger's, etc. carry. Dad was a millwright, keeping 100-200 ton presses running in those days, so am wondering if it may have been something that they used for final fitting of certain parts, but this was a small tub, so not sure. Thank you.
Old 12-01-2014, 05:23 PM   #5
Rewards Points: 1,692
The term you may be looking for is Jeweled Finish. Lapping compound was used and I've used emery tape adhered to a dowel. My son still has an old Disston hand saw I jeweled for him several years ago. It was a little rusty but that made it a real Jewel.
BTW that lapping compound on valves probably sold more sets of piston rings than any other single thing.
https://www.google.com/search?q=jewe...iw=864&bih=436
Old 12-01-2014, 10:18 PM   #6
Rewards Points: 406
I've also seen it called 'engine turning'. You use a dowel with either a paste abrasive or small sandpaper discs. I've seen it on the metal dashes of hot rods. https://en.wikipedia.org/wiki/Engine_turning
ChuckF. is online now   Reply With Quote
The Following User Says Thank You to ChuckF. For This Useful Post:
oh'mike (12-02-2014)
Old 12-02-2014, 07:15 AM   #7
Rewards Points: 120
Yup, looks like engine turning and/or jeweling is in the right ballpark. Thank you guys. Thinking back, I figured that it must have been a process that dad was working on at the shop at that time, as they did a fair amount of custom work, so hard telling, but the images that these searches brought up are exactly what I remember him showing me. I should have thought of these myself, but two examples familiar to a lot of people are the Spirit of St. Louis and hotrod dash boards. Well, nothing pressing, but something that I will dabble a bit with as I have some time over the winter, and now I have a starting point. Again, thank you.
Old 12-02-2014, 08:14 AM   #8
Rewards Points: 270
Around here it's called engine turning. My 61 Studebaker has it on the dash panel,and around 1976 or so,Pontiac Trans Am used it on the dash.
flhtcu is offline   Reply With Quote
Old 12-02-2014, 01:43 PM   #9
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
. . . . ..how to put a neat swirl affect on something metal. . . . . .
Lots of ways but it depends on which metal, smoothness, and look.
http://www.finishing.com/454/92.shtml
Disclaimer
& Stay Safe
.....Bob Lavery
Old 12-02-2014, 04:03 PM   #10
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
Ayuh,.... Glazin' compound is what We used to putty in a single pane window to the frame,....
Engine Turnin', is done with valve grindin' compound, 'n a dowel,...
Old 12-02-2014, 04:44 PM   #11
Rewards Points: 120
Oh yeah, believe me when I say that I have had plenty of experience with glazing windows, so know exactly what you are referring to. Engine turning and jeweling look like what I had in mind, but, again, I'm going back 40-50 years ago, so not so sure but what my memory is correct, and that terminology may have changed a little bit in that time. Maybe it has passed it's peak, because it seems less common today, but I have always liked it.
Old 12-06-2014, 06:43 PM   #12
In a little over my head
Rewards Points: 706
If the valve lapping compound is too coarse for the metal you are polishing, you might try rubbing compound, as is used to polish car paint. Or Simichrome. Polishing rouge comes in several grits. Try the Eastwood Company. http://www.eastwood.com/
http://www.eastwood.com/five-compound-tube-set.html
ratherbefishing is offline   Reply With Quote
use a Sharpie to simulate cabinet glazing? denemante Kitchen & Bath Remodeling 4 05-11-2014 09:10 PM
Fixing a Removable Glazing Panel Har Carpentry 5 11-16-2012 09:46 AM
How to calculate total glazing allowed in a wall? dalepres Building & Construction 3 04-22-2011 12:28 AM
window glazing Gatorgirl1 Painting 7 08-04-2009 02:23 PM
What do you think about Double Glazing with plastic sheets? foster01 General DIY Discussions 1 08-25-2008 04:12 PM
