Generator - Tools - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 07:15 AM   #1
Question
generator
Hi
I recently bought a house and at the moment I donít have electricity so I borrowed my fatherís generator 4.2kva (18 amps @240v). I have a 3 HP air compressor (9 amps when running). I tried the compressor on the generator (when the compressor was empty) and it did start and worked properly but then when I retried to start the compressor from half full with air it was just turning to start for a few second and it did not start completely ( I guess because of the extra load). I was wondering if there is something I can do to so I can use the air compressor without damaging anything.
Dose increasing the capacitor of the air compressor do any better or it will damage the compressorís motor in the long run?
i know that the best solution is to buy a bigger generator but do you have Any suggestions?
jsprinter is offline   Reply With Quote
Old 07-05-2010, 07:35 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
How much ext cord are you using? Try plugging compressor directly into generator (no extension cord) see if that makes any diff. If so, get a longer air hose and ditch the extension cord. the other option is renting a gas powered compressor ( you should be able to get one pretty cheap on a monthly rental, or pick up a used one on craigs list)
As for adding capacitors, I seem to remember there was a great thread on this a few months ago.
Found it, may not directly answer your question, but worth reading, and worthy of a bump
Air Compressor blowing start capacitors?
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 07-09-2010, 04:57 PM   #3
Rewards Points: 502
maybe adjust the startup pressure? so it runs down more before refilling.
how about a cetrifugal clutch on the end of the electric mootr, like they use on small gas engines?
forresth is offline   Reply With Quote
Old 08-04-2010, 10:33 AM   #4
Nailerman
Compressors are not recommended to run off generators because it can burn up the motor. I would look into purchasing a gas compressor.
AL
nailerman is offline   Reply With Quote
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
Generator with 2 transfer switches? Isaac-1 Electrical 4 03-16-2009 07:45 PM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Feeding multiple subpanels with a single generator monsoon Electrical 8 10-02-2007 04:25 PM
