Gas Power Washer - Tools - DIY Chatroom Home Improvement Forum
Old 05-17-2014, 01:09 PM   #1
Wench's Avatar
Rewards Points: 109
Gas power washer
I'm not sure if this is the right place to post this????
We have a gas power washer that will start with starting fluid but then stalls. Gas is getting to the carburetor but it will not keep running. Any ideas how to fix it?
Wench is offline   Reply With Quote
Old 05-17-2014, 03:05 PM   #2
Rewards Points: 6,034
If it has set for a while without running the ethanol gas has went bad.
Old 05-17-2014, 03:20 PM   #3
Gymschu's Avatar
Rewards Points: 1,036
Could be any number of things. Filter clogged, choke needs adjusted, spark plug finally done. Also, when the pump finally dies, it usually causes the motor to sputter or stop. Just a few thoughts.
Also, check the oil. Some PW's have "low oil shutdown" which shuts the engine off if the oil level is too low.
Old 05-17-2014, 06:16 PM   #4
Rewards Points: 14,312
Need to rebuild and clean the carburetor with carb. cleaner.
Only use nonethanol fuel, let it run out of fuel next time you use it once you get it running.
Old 05-19-2014, 08:35 PM   #5
Wench's Avatar
Rewards Points: 109
The gas was drained, the spark plug is good. Will have to check the other tips mentioned. Thank you, I will let you know if we get it started.
Old 05-20-2014, 09:27 AM   #6
landfillwizard's Avatar
Rewards Points: 516
Ethanol is very tough on plastic fuel lines. Check to make sure a fuel line is drawing air, or collapsed.
landfillwizard is offline   Reply With Quote
Old 05-20-2014, 09:59 AM   #7
Even if the gas was drained if it sat in the carb it has gummed up. I have a friend here in Fla. who does boat repair. He told me his income has jumped about $10,000 a year since ethanol. It's ok in cars but in something that sits say all winter it is harmful.
Old 05-20-2014, 10:31 AM   #8
Wench's Avatar
Rewards Points: 109
Well we are guilty of letting it sit a long time without using it....I think my husband is allergic to power washers
power washer Amateuralex Tools 17 06-02-2013 08:34 AM
Power Washer Seized wiz561 General DIY Discussions 13 05-07-2013 07:32 AM
Power washer engine spark0fun Tractors & Mowers 9 05-06-2013 07:41 PM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
bolt that holds the tank to the toilet bowl is leaking andrewjs18 Plumbing 13 04-06-2012 10:43 AM
