Framing Nailer... Why So Many Angles? - Tools - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 01:42 PM   #1
Rewards Points: 264
Framing Nailer... why so many angles?
I have amassed a number of Sears gift cards and want to buy a framing nailer to add to the arsenal. What is the usage difference between nailers of different angles? I see 21, 28, 32, etc.. Won't be building houses from the foundation up but finishing a basement or building a deck are well within the possibilities. Thanks all!
moneymgmt is offline   Reply With Quote
Old 04-18-2011, 02:09 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
I'm not an expert, but I think 21 is standard for full-head nailers. ~30-degree nailers typically used clipped-head nails. I could be wrong though.
Check into the price of nails. Often they vary by the nailers they will fit. You might kick yourself for buying a nailer that takes more-expensive nails when you start shooting them. I love my framing nailer - have used it on some minor projects and building my basement. Indispensable tool if you ask me. Probably because I'd be missing a thumb if I had to swing a hammer to frame.
hyunelan2 is offline   Reply With Quote
Old 04-18-2011, 02:16 PM   #3
21 degree is probably the most common, nails are usually cheaper at a lumber or other supply house, the big box stores charge almost 2xs for a case. Make sure you get a gun that shoots full round head nails, some codes dont accept clipped heads
mgarfield is offline   Reply With Quote
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Can I use a framing nailer as a roofing nailer? capslock Tools 1 06-10-2010 11:41 AM
Framing Nailer for home use? hyunelan2 Tools 21 10-17-2009 05:17 PM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 11:17 AM
Which Framing Nailer? - Compressor? hockeymatrix Tools 9 02-27-2009 07:31 PM
