Framing Nailer Repair - Tools - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 09:35 PM   #1
Rewards Points: 398
Framing nailer repair
I have a Dewalt D51844 framing nailer. It will no longer shoot nails. When I press the trigger, I can hear air coming out of the trigger area. Is it easy to repair framing nailers?
Malcolm is offline   Reply With Quote
Old 03-13-2013, 09:43 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,062
if youve never repaired a nailer best not try it . you could easily make things worse by not putting it back together correctly..
by the sounds of it you might have a bad oring
woodworkbykirk is online now   Reply With Quote
Old 03-13-2013, 10:01 PM   #3
Rewards Points: 398
I was doing some research and it could be the trigger valve or o-ring around the valve.
It doesn't seem like it is too bad of a repair. I may try it. If not, I'm just going to throw it away. I don't want to pay for it to be repaired.
Old 03-13-2013, 10:58 PM   #4
Davejss's Avatar
Rewards Points: 740
It's almost always just an O-ring. Cheap, simple fix.
Davejss is offline   Reply With Quote
Old 03-13-2013, 11:11 PM   #5
Rewards Points: 13,300
That one gun comes 4 differant ways with the same model #.
http://www.ereplacementparts.com/sea...1844&x=22&y=17
Old 03-14-2013, 08:38 PM   #6
your right joe, i forgot about that.. the dewalts have interchangable triggers to suit the user if they want bounce fire or single fire mode.... i dont get having that on whats supposed to be a pro grade tool.. its probably why dewalt doesnt sell many framing guns.. along with the fact they jamb easily
Old 06-30-2013, 05:36 PM   #7
Rewards Points: 398
I finally got around to looking at it. The trigger valve assembly is leaking. Specifically, there are two clear o-rings inside the trigger assembly that have deteriorated. I can't find the o rings sold separately from the valve. Where can I find this type of O ring? Unfortunately, the o rings fell to pieces, so I can't compare it to anything. I was thinking about checking a tool repair shop.
Old 06-30-2013, 06:23 PM   #8
No way would I just replace the trigger o rings while I had it apart.
Buy the whole rebuild kit and redo the whole thing.
I get the whole thing done at a factory authorized repair shop for $75.00.
Old 06-30-2013, 07:55 PM   #9
Rewards Points: 398
It's really easy to remove the trigger guard and valve. You could save money, and more importantly down time, by doing it yourself. You just have to remove a few pins.
Old 07-01-2013, 01:13 PM   #10
Rewards Points: 260
bluefitness is offline   Reply With Quote
replacing 'o' rings in a PFR 2190 framing nailer Michael Davis Building & Construction 0 08-21-2012 01:08 PM
framing nailer: coil or traditional jasonp03 Tools 2 08-02-2012 03:55 PM
Need Framing Nailer Recomondation MikeP Tools 16 09-19-2009 12:37 PM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 12:17 PM
Framing Nailer Pressure Requirements dmend Building & Construction 10 09-28-2007 03:37 PM
