Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-14-2012, 08:40 AM   #1
Framing Nailer -HELP-
Hello,
I'm a newbie and I'm looking to buy a nailer to do my framing work for the basement. Can someone please recommend a good reliable framing nailer?
Thank you in advance everyone!
bcdinh is offline   Reply With Quote
Old 06-14-2012, 08:52 AM   #2
Super Moderator
First--look for one that has easily available nails----
I bought a Porter Cable several years back---I needed a back up gun and it was cheap---
My good gun was stolen shortly after that----the Porter able has served me well----lots of use--no problems.
Old 06-14-2012, 09:02 AM   #3
Thanks for your response oh' mike. What you do think of a Max SN883RH2, Ridgig, or Bostitch rounded head nailer?
Old 06-14-2012, 09:38 AM   #4
Super Moderator
Bostich are good,but the nails are expensive---Never used the other two that you mentioned--
You will not put much wear and tear on whatever gun you buy---so a lighter --cheaper gun should serve you well----Hitachi--Senco---Bostich--Pasload are all premium pro guns---if they are in your budget a pro gun will last you a lifetime---but perhaps a waste of money for occasional use for household projects.
bcdinh (06-14-2012)
Old 06-14-2012, 10:13 AM   #5
Hi oh'mike,
I found this great link that talks all about framing nailer "http://www.toolsofthetrade.net/industry-news.asp?sectionID=0&articleID=649074&artnum=1". What do you think of it? I'm thinking of going for the Paslode 3-1/2 or Senco SN902XP as what you suggested. Although the Max SN883RH2 is very tempting too because it has good review from the author
Thanks a lot oh'mike
Old 06-14-2012, 05:07 PM   #6
In a little over my head
Paslode, Bostich, Senco, Hitachi, Porter Cable all make good stuff. Considering that a professional framer will drive more nails in a month than most DIY will do in a lifetime, you won't go wrong with any name brand. I have a Porter Cable that has framed several sheds and a couple additions. Probably 3-4 boxes of nails. Still works good as new. When my carpenter buddy (a Bostich/Paslode/Senco owner) was using it on my roof, he said "Wow, that's a nice gun." Whatever you buy, oil daily and try not to drop it off the ladder.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
oh'mike (06-14-2012)
Old 06-14-2012, 07:12 PM   #7
are you looking for a cordless or an air gun?
princelake is offline   Reply With Quote
Old 06-14-2012, 11:27 PM   #8
Jack of all - master none
hyunelan2's Avatar
For what it's worth, I bought a used/recon gun on eBay - a Campbell Hausfeld for about $70. Some guy was selling a few of them that all had new seals in them... my guess is a big-box employee who took returns out of the trash.
Anyway, it shoots 21 degree nails I can get generic at Menards/HD. It framed my whole basement, plus some other projects for both me and people I've let borrow it. Only had one bad jam in all of that (some minor jams though). I would bet that I would have wasted more than $70 on bent nails if I had to swing a hammer at them all. If you only have your own basement on the horizon, that would be the way I would go.
hyunelan2 is online now   Reply With Quote
The Following User Says Thank You to hyunelan2 For This Useful Post:
oh'mike (06-15-2012)
Old 06-15-2012, 09:59 AM   #9
I'm interested in a air gun.
The Following User Says Thank You to bcdinh For This Useful Post:
oh'mike (06-17-2012)
Old 06-18-2012, 03:27 PM   #10
jschaben
Here's the one I have. Reconditioned but works just fine. Cost about the same as 2 days rental around here. You can probably get one cheaper, I've seen Harbor Freight for about $90 but I'm 0 for 3 on Harbor Freight pneumatics. I know a lot of people are happy with them but just hasn't worked for me. Partly because I'm a 2 hour drive from their nearest retail outlet so their liberal exchange policy doesn't mean much to me.
http://bigskytool.com/Hitachi_NR90AE...f=jdzlymblxayi
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
bcdinh (06-18-2012)
Old 06-18-2012, 09:18 PM   #11
i have the harbor freight "3 in 1" framing nailer. so far it has worked GREAT. it is the more expensive one. the cheaper one is junk, so i hear.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 06-19-2012, 12:00 AM   #12
thank you everyone. ive decided to go with the hitachi nr90ae(s) from lowes and a 16g finish nailers. the nr90ae is a lot cheaper then the nr83a2 and both spec are very identical but i do not know why one is cheaper then the other.
Old 06-19-2012, 08:12 AM   #13
jschaben
The 83 is a 34° nailer and the 90 is a 21°. Many prefer the higher angle as they can access tighter places. On the other hand, the 83 is a clipped head vs. the 90 being a full round head nailer. Clipped heads don't always meet local codes.
John Schaben
Old 06-19-2012, 08:20 AM   #14
No they are both 21deg nailers.
Old 06-19-2012, 10:11 AM   #15
jschaben
http://bigskytool.com/Hitachi_NR83AA...r___i1365.aspx
select the specs tab
Edit - just noticed the AA3 is a 34° and the A2S is a 21°. Never have figured out the Hitachi model numbering system.
John Schaben
Framing Nailer of Death! Oh-Fudge Tools 6 09-15-2011 10:11 PM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
Can I use a framing nailer as a roofing nailer? capslock Tools 1 06-10-2010 12:41 PM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 12:17 PM
Which Framing Nailer? - Compressor? hockeymatrix Tools 9 02-27-2009 08:31 PM
