Fixing Dropped Air Stapler - Tools - DIY Chatroom Home Improvement Forum
Old 12-29-2008, 08:14 PM   #1
fixing dropped air stapler
Hello all,
I recently dropped an old bostitch narrow crown stapler (s32sx). I took the gun apart but could find nothing obviously wrong.
When the trigger is depressed air flows out the exhaust and around the trigger area, but the plunger never fires.
So I replaced the trigger assembly, but that did not fix the problem. Looking at the gun and the parts diagram [1] I can't figure out what else could be the problem.
Does anyone any idea of what might break on an air nailer/stapler when it is dropped?
Thanks in advance,
chip
References:
[1] http://www.bostitch.com/default.asp?...2SX&serialNum=
cwebber is offline   Reply With Quote
Old 12-30-2008, 07:43 PM   #2
(the original)
Rewards Points: 756
Sounds like the problem is in the piston/cylinder assembly. Could be a cracked sleeve, jammed piston, or could be as simple as a displaced seal.
ratherbefishin' is offline   Reply With Quote
Old 12-30-2008, 08:02 PM   #3
Man of many hats
wrangler's Avatar
Rewards Points: 354
Have you oiled it? Mine will do that occasionally, and 4-5 drops of oil into the air inlet usually solves the problem.
Man of many hats
wrangler is offline   Reply With Quote
Old 12-31-2008, 08:09 AM   #4
Yes I applied liberal amounts of oil - that's the first thing I tired since it was the easiest
Old 12-31-2008, 08:19 AM   #5
Registered User
Termite's Avatar
Sometimes rapping the thing against a solid piece of wood will pop it back. Unfortunately, two Bostitch guns that I own have done the same thing and need to be repaired. I won't buy another Bostitch because of it.
Old 12-31-2008, 08:19 AM   #6
That makes sense. The piston and ring slide freely up/down clyinder, so I'll give the rest of that assembly a closer look and report back.
Old 01-01-2009, 12:16 PM   #7
Solution
Thanks for the help. I finally fixed the gun so I thought I would post the solution here in case anyone else has the same issue.
I finally got a hold of another gun and started swapping parts in until I isolated the problem. It turns out there were no broken pieces in the gun, and no seals or O-rings noticeably out of place.
The problem was in the head valve assembly (right under the exhaust port above the cylinder). It is supposed to seal with the top of the cylinder and is held in place by a spring and the bumper/piston stop. When I took apart the head valve, re-greased everything, and put it back together the gun started working normally.
I think the spring that tensions the head valve got bumped out of place slightly in the drop so that it no longer formed a tight seal with the cylinder. Perhaps another hard bump would have also knocked it back in place (as was suggested above).
Many thanks,
chip
Old 12-24-2010, 07:41 PM   #8
Bostich air stapler repair
Thanks for your post on servicing the head valve assembly of an air stapler. I had torn down my Bostich twice with no success and was about to give up when I saw the post. Now it's working fine and one less item in the landfill.
ironimaginings is offline   Reply With Quote
Dropped ceiling duct work. rusty model a HVAC 9 11-15-2008 08:58 PM
Horizontal drywall w/ dropped ceiling ClnlBrahm Drywall & Plaster 2 09-02-2008 12:38 AM
Undermount Bath Sink Dropped capt2 Plumbing 4 08-27-2008 10:35 AM
fixing cracked caulking on mdf painted trim cinnabon Painting 5 04-15-2008 04:49 AM
BOSTITCH Hardwood Flooring Stapler Ciprillius Flooring 3 11-28-2007 07:16 AM
