Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 11-20-2012, 10:19 PM   #1
Fixing cordless tool batteries
I have a few 12v Dewalt Nicad batteries that are no longer taking charge.
I found on ebay they sell instructions on how to EASILY fix these batteries.
http://www.ebay.com/itm/BATTERY-FIX-for-DEWALT-7-9-6-12-14-4-18-24-V-VOLT-18v-/271092358456?pt=LH_DefaultDomain_0&hash=item3f1e5d 1d38
Do these instructions work?
Local tool stores charge $40 to restore ONE battery...can a $4 instruction booklet do the same?
miamicuse is offline   Reply With Quote
Old 11-21-2012, 01:27 AM   #2
For me I purchased the rigid line of cordless drills because the batteries are guaranteed for life so I wouldn’t have that problem. I already replaced two sets of batteries which I had for about 9 years and finally died. I just called them up, gave them my serial #’s was given a reference # and a place to drop off and pick up new batteries no questions asked. Note, in order for this to work you have to call and register your new tools/batteries or else you will have problems.
epson is offline   Reply With Quote
Old 11-21-2012, 03:35 AM   #3
(the original)
Save your money, that info has been around for years for free. I can't believe scammers are still trying to sell it.
http://ysuusy.com/easybatteryfix.html
It's a temporary fix that will give you a little more life if the battery isn't too bad. Don't expect it to be like new, though. You can get full voltage, but your Ah will be lower.
Shops don't "restore" batteries, they rebuild them. The good ones use quality, higher Ah rated cells and you end up with better than original.
ratherbefishin' is offline   Reply With Quote
Old 11-21-2012, 11:06 AM   #4
JOATMON
ddawg16's Avatar
I'm sort of an expert on NiCads (I used to design test equipment to test new batteries).
When a NiCad is reaching the end of it's life, what has basically happened is that the surface of the coil inside is getting coated with an oxide. Except for the occasional short between plates, all those trick do little to get any real life out of a battery.
NiCad's have a basic life of between 300 and 1000 cycles....and/or about 10 years. Even if you don't use a NiCad much...it still ages....
On some of those battery packs, maybe only one battery is bad....if you have a soldering iron and a replacement battery....you can remove the bad one and put in a good one....
Some advice on getting the most life out of your batteries.
1. Run them down until basically dead.
2. Fully charge but don't leave them on the charger...that reduces the life.
3. Try to avoid letting them get too cold...NiCad's don't like cold
5. Write the purchase date on the battery along with a #.
6. If you don't use a batter for awhile....on some chargers, putting a battery in it with out it plugged in will discharge the battery. Do that...then fully charge it.
7. Avoid re-charging a half discharged battery.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
The Following User Says Thank You to ddawg16 For This Useful Post:
PaliBob (11-21-2012)
Old 11-21-2012, 01:26 PM   #5
Tool Geek
PaliBob's Avatar
There is a video going around that claims to Only help Ni-Cads
& Stay Safe
.....Bob Lavery
Old 11-21-2012, 04:47 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
just buy new batteries or replace the tool all together
woodworkbykirk is online now   Reply With Quote
Old 11-21-2012, 05:51 PM   #7
STAFF
BigJim's Avatar
I think you can get the little batteries inside the tool battery at Radio Shack and rework them yourself for a lot less. I haven't tried this but I can see how it would work.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Old 11-21-2012, 07:48 PM   #8
Isn't this the reason why the chargers, or in some cases the batteries, have fancy electronics and things like "maintenance modes?" My understanding is if you just put them in the charger, the charger will do the right thing?
I have DeWalt 18V XRP and am about to pick up some 20V MAX. I assume the "20V" technology is newer and better, and since I need a couple of new tools anyway, I figure it is a good time to make the change. My 18V batteries have really lasted a long time. The first set I got in ~2000 and I replaced them only once. All I do is put them on the charger when I am through using them for the day.
jeffsw6 is offline   Reply With Quote
Old 11-21-2012, 07:50 PM   #9
the problem with doing this is you seriously run the risk of frying the tool if you dont do it correct.. finehomebuilding magazine did an article on just this topic a few years ago.
Old 11-21-2012, 08:09 PM   #10
JOATMON
ddawg16's Avatar
Jeff....chances are anything new will be Li. Whole different animal....I looked at the physical/electrical characteristics a while back....they way you charge/maintain them is different from NiCad.
For NiCad chargers.....a majority of them (newer ones) use the smart charge feature....basically, if it fully charges a dead battery in an hour or less and has a 'charged' light, then it uses the 'smarter' technology. Typically it uses a pulsed input charge. This helps to break down the oxide that developes on the plates and reduces the heat up of the battery. In most cases, the battery is considered charged when the temp suddenly rises and/or current going into the battery drops below a certain amount. Temp is the more common method. When a battery is fully charged, since the electrolyt can't hold any more electrons, the engery going in is disapated as heat. That is why some chargers will show a battery as charged if you have just finished using it in a high current task and it's real warm. It won't charge until it cools down.
My
and
PaliBob (11-22-2012)
Old 11-21-2012, 11:37 PM   #11
STAFF
BigJim's Avatar
You are right, I didn't think about someone getting the wrong batteries, that would be a double whammy, both battery and tool shot.
Jim
Old 11-23-2012, 05:34 AM   #12
Tool Geek
PaliBob's Avatar
There has been some excellent points brought up on cordless tool batteries
In this thread, let me add a few.
On Battery Replacement:
For Ni-Cads (New tools are still being sold with Ni-Cad Batteries)
Rather than buying new battery packs check out these prices:
http://www.batteriesplus.com/t-storeloc.aspx
Are DeWalt 20V Max Batteries a higher voltage than 18V?
Answer; NO, DeWalt's purpose was ostensibly was just to identify
the new slide on battery pack from the original 18V plug-in battery.
https://enr.construction.com/product...mionlineup.asp
Bosch also now uses the Max Name on 12V Tools
Three years ago when I first bought a ¼” Bosch Driver the
Li-Ion battery was rated at 10.8 V. Last year I got a Bosch
¼” Bosch Impact Driver, same size battery but now instead
of 10.8 V it is called 12V Max
Explanation on why
& Stay Safe
.....Bob Lavery
Old 11-23-2012, 11:09 AM   #13
JOATMON
ddawg16's Avatar
let me add a few.
Explanation on why
It must be the 'fully charged' vs 'normal charge'.
A typical NiCad will measure around 1.4 Vdc when fully charged. During the typical discharge, the voltage will drop down to around 1.2 Vdc....once you get below about 1.1v.....the battery is pretty much done....after that the voltage drops off quick.
Nice thing about NiCad's is that they have a pretty flat discharge curve.
Here is an interersting read on Li-ion...
http://en.wikipedia.org/wiki/Lithium-ion_battery
Chemistry, performance, cost, and safety characteristics vary across LIB types. Handheld electronics mostly use LIBs based on lithium cobalt oxide (LCO), which offers high energy density, but have well-known safety concerns, especially when damaged. Lithium iron phosphate (LFP), lithium manganese oxide (LMO) and lithium nickel manganese cobalt oxide (NMC) offer lower energy density, but longer lives and inherent safety. These chemistries are being widely used for electric tools, medical equipment and other roles. NMC in particular is a leading contender for automotive applications. Lithium nickel cobalt aluminum oxide (NCA) and lithium titanate (LTO) are specialty designs aimed at particular niche roles.
and of real interest...
Avoid deep discharge (depletion) and instead charge more often between uses. The smaller the depth of discharge, the longer the battery will last.[104][unreliable source?] [105]
Avoid storing the battery in full discharged state. As the battery will self-discharge over time, its voltage will gradually lower, and when it is depleted below the low-voltage threshold (2.4 to 2.9 V/cell, depending on chemistry) it cannot be charged anymore because the protection circuit (a type of electronic fuse) disables it.[104][unreliable source?] It is frequently recommended to store batteries at 40% charge level.[106]
The rate of degradation of Lithium-ion batteries is strongly temperature-dependent; they degrade much faster if stored or used at higher temperatures and may even be stored in a refrigerator.[104][unreliable source?][107][108]
My
and
Old 11-23-2012, 12:49 PM   #14
Tool Geek
PaliBob's Avatar
This is really Off Topic, but today I got an Ad
for a really hot deal on a Bosch Combo Kit
(+ additional $25 off at checkout}
& Stay Safe
.....Bob Lavery
Old 11-23-2012, 12:56 PM   #15
JOATMON
ddawg16's Avatar
That is a good deal....only problem is that it's 12v.....I'm an 18v guy.....
My
and
Advice on 18v cordless tool set? ChrisWhitley Tools 17 04-16-2012 09:58 PM
Power tool batteries and maintenance Albe Tools 4 03-04-2012 04:44 PM
Batteries dying if left in the cordless tool? General Tools 8 12-23-2010 08:44 PM
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 02:31 PM
Cordless Drill Batteries MrBill_DIY Tools 11 01-15-2009 05:17 PM
