-   Tools (http://www.diychatroom.com/f29/)
-   -   First Chain Saw (http://www.diychatroom.com/f29/first-chain-saw-67097/)
tb582 03-18-2010 10:53 AM
First Chain Saw
Hey Guys - I have another thread going over the the 'Landscape' area (http://www.diychatroom.com/f16/brush...l-trees-63196/) but my main question for you is that I need to get my first chain saw to cut down the brush that's discussed in that thread.
Know that I have never used a chain saw before I dont want to get one thats too powerful, but I also don't want a wimpy POS either. Can you guys recommend some exact models that would be good for me?
Scuba_Dave 03-18-2010 11:23 AM
Those are some pretty decent sized trees to cut if this is your 1st time
The problem in many cases is when the tree starts to fall
If it falls in the wrong direction it can damage property or kill you
Another problem is the wind picking up & blowing the tree over in the wrong direction as you are cutting it
An 18 inch saw is a pretty standard size
But it needs to be long enough to go thru the tree you are cutting
So you need to know the diameter of the tree
I bought a Husqvarna model with a 28" blade & a 20" blade
I cut quite a bit of wood & had a tree trunk ~54" across that I needed to cut up
I actually use sawzall to cut smaller trees down
Blade is easily replaced in case it gets stuck
And the sawzall was only ~$80
I tie the tree off in the direction I want it to fall - actually pulling it in that direction 1st
I then cut most of the way around the tree
Then I use my truck to pull the tree down, or if smaller by hand
I've topped 5 trees around my property using this method
B4:
http://i4.photobucket.com/albums/y10...tback2fall.jpg
After
http://i4.photobucket.com/albums/y10...ts/Waiting.jpg
One on the left topped, one on the right started
http://i4.photobucket.com/albums/y10...ants/Side2.jpg
Giles 03-18-2010 11:56 AM
There is no such thing as a perfect "do-it-all" saw. If you get a saw with a 16" bar, you can cut a tree 32" diameter. But it will be very dangerious and difficult to cut a larger size tree.
On the other hand, a saw with 20" bar will cut a bigger tree but will be heaiver and more difficult to use on small stuff.
I have three saws--16"-18" Husky, a 20" Stihl, and a 12" Jonsered that I use trimming small limbs.
So-----I would suggest that you purchase a 14" or 16" saw.
The higher priced saws, are usually lighter and just one pound makes a big difference when you are using it for several hours.
I would also suggest that you buy from a reputable dealer that can advise you as to what brand and size saw that you would be happy with.
tb582 03-18-2010 12:32 PM
Great advice - Thanks, nothing I have to cut down is no where near that big so I think I'm going to shoot for a 16''. Now to figure out exactly which one.
tb582 03-18-2010 12:42 PM
Ok I'm compairing these ones here:
http://www.husqvarna.com/us/homeowne...,166319,188833
Anyone have any experience with these? recommend one over the other?
Thurman 03-18-2010 01:18 PM
This is no joke: Recently I got out my green chain saw, which had not run in at least three years. NO, I never got it to run and was fed up with trying. I happened to go to a big box store for something else, and decided to price a new chain saw. They have electric chain saws out now! There were two on sale so I bought the 16" one. After getting home and getting it ready to trim small tree limbs, etc., my wife comes out and--of course--what's that? Well, she tried it and I have not been able to use it since---that's a shame :thumbup:. Solution: But an electric chain saw. Women don't like gas powered anything's, but do like electrical appliances. :whistling2: David
cellophane 03-18-2010 04:22 PM
personally the 2LB difference between the homeowner and other models would be a big factor. lugging a saw around all day gets pretty tiring and any weight you can trim off (no pun!) is good.
houseinthewoods 03-18-2010 04:59 PM
I have a Husqvarna Rancher 55 with a 20" bar. It was great for felling trees. It had enough power to tackle anything as long as I kept the chain sharp. It's relatively easy to start, and has been completely bulletproof.
When it came time to start cutting up all the small branches, the thing killed me. It's no lightweight, and hefting it around to cut up small branches was VERY tiring. You don't want to have your arms cramping up while you're handling a chain saw.:eek:
I really recommend a light-weight saw for light-weight work.
tb582 03-18-2010 07:35 PM
The only thing I can tell is that the homeowner saw has alot more 'features' than the lighter ones... Do you think those features are worth the extra weight?
Leah Frances 03-18-2010 08:07 PM
A days worth of sawing is brutal with a heavy saw. I have a Stihl homeowner - the same one that my tree-guy keeps in his truck for when he doesn't want to fire up his big bar.
cellophane 03-19-2010 08:39 AM
a lot of those features are on that list twice ;)
even with all that stuff that i don't even know what it means - i would buy the lighter saw. as everyone has mentioned using a lighter saw will save your arms and back in the long run, unless you really need a huge saw for some reason.
DangerMouse 03-19-2010 11:36 AM
I recommend the Stihl MS170! (MS = "Mini Saw")
I use it more than my larger Dolmar just because it handles 80% of what I do with ease.
The Dolmar rocks for anything larger......
I also keep a 14amp electric in the woodshed for the odd piece that needs it.
DM
tb582 03-19-2010 01:47 PM
DM
I read your post figuring that the MS170 was actually Mini Saw only to go onto Stihl's website and find that 95% of their saws all have MS in the model number :( - I was also looking at the weights of some compared to the ones I have above from Husq. and they are heaver in most cases.
Is it worth the extra weight? I'm looking to spend <=350 for my new saw and really dont want to get something too powerful. I dont have anything huge to take down just very small trees and brush type stuss... I want to get the best saw I can without going overboard.
DangerMouse 03-19-2010 01:53 PM
My 170 is pretty light, and it only ran $160 new....
It was on sale for that much last year too. (mine is 5 or 6 yrs old)
It seems like a good saw for your needs IMHO.
DM
Jonsjumps 03-24-2010 12:27 AM
Dangermouse is right about the MS170. I have a MS170 and a MS660. The 170 is a great little saw and you can get a low kickback chains for it(which would a great idea for a new user). I've had mine for about 6 or 7 years and still starts on the first pull.
