Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 05-18-2012, 06:02 PM   #1
Finish nailers
I already own a Bostitch 18 gauge brad nailer. I am considering adding either an 16 gauge or 15 gauge finish nailer to my arsenal. I am an avid DIY'er who likes adding toys. Since I already have an 18 gauge brad nailer, am I better off getting the 15 gauge over the 16 gauge in your opinion. Again, don't really need one, but adding to my toys. Mostly used for trim purposes.
pkrapp74 is offline   Reply With Quote
Old 05-18-2012, 06:50 PM   #2
Finish nailers
i say since you already have the 18, i'd go with the 15.
princelake is offline   Reply With Quote
Old 05-18-2012, 06:54 PM   #3
KemoSabe
loneframer's Avatar
Finish nailers
I would go with the 16 gauge. I've been building new homes for almost 30 years and 16 gauge is by far the predominantly used tool for trimwork.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
woodworkbykirk (05-18-2012)
Old 05-18-2012, 07:52 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Finish nailers
trust me lone knows his stuff, you dont wanna compare nail gun collections with him
honestly though, the 15 gauge does have more holding power due to the larger shank and larger head, however it leaves a larger nail hole and nails or it cost quite a bit more than 16 gauge nails
i trim out new construction homes and high end reno's all the time and i use a 16 gauge for interior trim (hanging doors, setting window boxes, built in shelving) with no issue. we do have a 15 gauge but its kept for exterior trim purposes when using Azek trim, it requires the extra holding power to hold up against the elements
woodworkbykirk is offline   Reply With Quote
Old 05-20-2012, 06:09 PM   #5
Finish nailers
So a 16 gauge will handle just about anything a DIY'er may come across? I don't think I would come across an application needing galvanized nails that requires the 15 gauge.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Finish Nailers LBJ Carpentry 5 03-12-2012 09:46 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
