Final Cut Saw Blades? - Tools - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 02:46 PM   #1
Rewards Points: 459
I'm looking to purchase a quality finish blade for my 10" table saw. I'll be ripping mostly pine trim and some shelving (not quite sure of the material yet, probably some sort of melamine coated ply).
I'm considering one of these Final Cut blades:
The idea seems simple enough - A thin kerf blade with a sanding disk adhered to it.
I've read older reviews that said that the paper shredded, but newer ones suggest that they changed the adhesive and haven't seen that problem since.
Has anybody tried this blade?
Nick DIY is offline   Reply With Quote
Old 12-13-2010, 06:42 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
i remember my buddy telling me about these a couple years ago. He must have had one of the early ones, because the paper just fell off one day. He was impressed with the blade up to that point....
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 12-14-2010, 09:04 AM   #3
Rewards Points: 150
If your saw allows it get a zero tolerance insert for the table and a good blade. That will give you nearly flawless cuts and last longer I think the final cut blade looks like gimik.
STL B. is offline   Reply With Quote
Old 12-14-2010, 12:39 PM   #4
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Yes, get a zero tolerance insert. As far as the blade goes, I would suggest that you buy a Freud - that's all I use.
WirelessG is offline   Reply With Quote
Old 12-19-2010, 11:28 AM   #5
Drywall contractor
Rewards Points: 1,070
Or a Diablo thin kerf. They're good too. I was tempted to try the Final Cut when I first saw it, but resisted temptation.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
I keep bending blades in recip saw acerunner Tools 10 08-22-2010 11:35 AM
Final Inspection Questions docmattman Building & Construction 6 07-15-2010 07:11 PM
Which saw blades are worth sharpening? ovahimba General DIY Discussions 2 06-02-2010 05:24 PM
Sears 536.884351 auger blades are discontinued, no replacement MichaelLit General DIY Discussions 2 07-08-2009 06:43 AM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 04:50 AM
