Filling And Bleeding A Floor Jack - Tools - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 03:19 PM   #1
Rewards Points: 256
filling and bleeding a floor jack
I lost my unsrtruction manual on my larin brand floor jack and need to fill and bleed it . but have no clue on the proper procedure ...
there is a slot headed screw on the right side of the open/ close valve and a larger allen screw on the left side of the open/ close valve .. i think one is the fill valve and one is a relese valve .... any ideas on how to properly bleed and fill a floor jack? also can power steering or brake fluid be used ?? i tried searching the web but nothing signifigant showed up.
Im hoping to save a hundred on a new jack if i dont need to . but cant let a hundred stand in the way of progress either . thats alot of scratch me offs or pop money .
oldrivers is offline   Reply With Quote
Old 09-23-2010, 03:22 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
use jack oil
http://www.hyjacks.com/H7.HTM
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
Thurman (09-24-2010)
Old 09-23-2010, 10:13 PM   #3
Rewards Points: 256
well i figured it out, it was a little rubber cork plug covered in greese.
Draining and then filling and bleeding system Nat1020 Plumbing 12 11-20-2008 12:29 AM
