Fein Multimaster - Tools - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 02:11 PM   #1
Rewards Points: 156
Fein Multimaster
I borrowed this tool off of a friend who bought it and never used it. This thing is a beast, I never thought I'd use it so much. Problem is, I should of taken into consideration the cost of the blades before dulling them all up.
Does anyone know where I can find cheap blades for this thing? $20+ per blade is absolutely insane, they don't even last too long.
It is a sweet tool though, I'd probably go with a cheaper brand though, now that a bunch of different companies are making them.
Branden is offline   Reply With Quote
Old 11-08-2010, 02:25 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
is it fair you replace the blades with something other than what you borrowed?
just in case you need help, no, it isn't.
You should talk to your friend before doing anything such as this. You might find yourself buying Fein blades and getting stuck with whatever you buy and try to pawn off on him. Then again, he might not care.
Old 11-08-2010, 04:12 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Multiblades a small independent California company has been making Fein replacement blades almost since day one. They have come out with new blade styles besides the Fein replacements and also a new 'square hole' blade design.
Besides Fein Multimaster they also make high quality blades for the Bosch, Rockwell, Dremel, and Harbor Freight oscillating tools.
Disclaimer
& Stay Safe
.....Bob Lavery
Last edited by PaliBob; 11-09-2010 at 01:58 PM. Reason: Bad Link s/b http://multiblades.com/
The Following User Says Thank You to PaliBob For This Useful Post:
Branden (11-08-2010)
Old 11-08-2010, 04:33 PM   #4
Rewards Points: 156
nap,
He is also trying to find out where to get lower priced blades and we are both searching for a place to get them.
PaliBob,
Thanks for the info, I think I'll be ordering blades off of them in the near future.
Old 11-08-2010, 04:58 PM   #5
Rewards Points: 258
Try bargainblade.com
retired guy 60 is offline   Reply With Quote
Old 11-08-2010, 05:23 PM   #6
nap
You talking to me?
nap's Avatar
Originally Posted by Branden View Post
nap,
PaliBob,
I understand that and I do not fault the guy but in both a legal and moral sense, he used up Fein blades so he needs to either replace with Fein blades or ask the owner of the tool if some others would be acceptable.
and after I read that 3 times, I realized I was responding to the OP and he was speaking about the owner of the tool.
If the owner is fine with something other than Fein, then all will be fine. Until you posted that, there was no way to determine the owner was fine without Fein but now we know his is fine without Fein, you will be fine if you do not purchase Fein but I would expect you to buy something just as fine as Fein blades.
Old 11-08-2010, 05:48 PM   #7
Registered User
Rewards Points: 526
Two for $8, reg $12 at Sears.
Gary
Multimaster is this (or the Sonicrafter) worth the $$ rossl56 Tools 67 02-16-2011 06:38 PM
Thoughts on a Dremel Muli-max? JCAHILL4 Tools 32 04-23-2010 01:38 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
