Fastener Size Selection - Tools - DIY Chatroom Home Improvement Forum
Old 03-09-2010, 08:29 AM   #1
I have a novice question - with the huge array of fasteners available, how do you know which type is the correct one to use? Is there a chart that says if the wood (or metal etc) is X dimension use Y screw? Obviously if you need to screw or nail through 3 2xW members you need a longer fastener - but how is the diameter chosen correctly.
cellophane is offline   Reply With Quote
Old 03-09-2010, 07:35 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by cellophane View Post do you know which type is the correct one to use?.........
With all the possible variables there is no simple answer. Here is a start with a chart on connecting to plywood with nails or screws.
If you have a specific question e.g. How to fasten a grab bar to a fiberglass shower enclosure you will get a whole range of replies some better than others, but then it all depends on the specifics of a particular situation.
& Stay Safe
.....Bob Lavery
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 08:13 PM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 05:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
