-   Tools (http://www.diychatroom.com/f29/)
-   -   Fastener Size Selection (http://www.diychatroom.com/f29/fastener-size-selection-66366/)
cellophane 03-09-2010 08:29 AM
I have a novice question - with the huge array of fasteners available, how do you know which type is the correct one to use? Is there a chart that says if the wood (or metal etc) is X dimension use Y screw? Obviously if you need to screw or nail through 3 2xW members you need a longer fastener - but how is the diameter chosen correctly.
PaliBob 03-09-2010 07:35 PM
Originally Posted by cellophane (Post 412022)
......how do you know which type is the correct one to use?.........
With all the possible variables there is no simple answer. Here is a start with a chart on connecting to plywood with nails or screws.
http://fasteners.hardwarestore.com/l...and-nails.aspx
If you have a specific question e.g. How to fasten a grab bar to a fiberglass shower enclosure you will get a whole range of replies some better than others, but then it all depends on the specifics of a particular situation.
