Dumb SDS Max Question - Tools - DIY Chatroom Home Improvement Forum
Old 03-18-2010, 06:22 PM   #1
Question
Dumb SDS Max question
Howdy,
I have a "1 9/16 inch SDS Max Rotary Hammer"
I've looked around and can't find what the "1 9/16" refers to. Is that the maximum shank size of the bit, or is that the maximum hole size that I can drill into concrete?
Another way to ask the same question: does my rotary hammer accept every single SDS-Max bit under the sun, or are there some SDS-Max bits with shanks larger than my rig can handle?
Thanks.
jstevens60 is offline   Reply With Quote
Old 03-18-2010, 07:48 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Bosch
11240
1-9/16 In. SDS-Max Combination Hammer - 10.0 Amp Combination Two-Mode Selector: Rotary Hammer and Hammer Only
10.0 Amp - Impact Energy (ft. lbs.) 5.2
No Load RPM 400 - No Load BPM 3,000
Length 17.25" - Weight (lbs.) 13.2
Max. Hole Diameter in Concrete 1-9/16"
Max. Hole Diameter in Concrete-Core Bit 4"
Max. Hole Diameter in Concrete-Thru Hole Bit 2-1/2"
Optimal Concrete Capacity Range 1/2 - 1-3/8"
Includes Carrying Case
that was from http://www.mytoolstore.com/compare/cphamr3.html
based on that, I would suggest it is the largest hole suggested to drill in concrete using a standard style bit. Obviously if you use core bits, you can drill larger holes.
Maybe that is the largest masonry drill bit they make with the sds max style arbor.
edit:
nope, found a 2" so that's not it. I would guess the largest suggested size standard style drill bit recommended
Old 03-19-2010, 01:46 PM   #3
I spoke to a tool guy and he said all SDS Max are a standard shank size, so that makes it easy.
What confused me is that with a "3/8 inch drill" or a "1/2 inch drill", the dimension refers to the max shank size.
Tags
"rotary hammer" "sds max"
Dumb question, how do you twist your wires together? Piedmont Electrical 62 04-13-2010 02:50 AM
Dumb HVAC question... 737Pilot HVAC 6 11-03-2008 03:56 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Dumb Siding question 1610 CUB Building & Construction 4 08-23-2008 04:08 PM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 06:55 AM
