Dual Saw Work To Cut Cement Board? - Tools - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 06:43 PM   #1
Rewards Points: 562
dual saw work to cut cement board?
saw a dual saw say they can cut anything???does that include cement board???
If it does work does it ruin blades quickly?? and does it create less dust than a circle saw and masonry blade??
are there brands to buy,,,and not buy???
4just1don is offline   Reply With Quote
Old 07-31-2011, 06:45 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I have seen somewhere that there are diamond blades available for the dual-saw but have never seen or used one first hand. There will be dust I'm sure.
XXX
Old 07-31-2011, 07:06 PM   #3
Ridgid makes good saw for cement board with a exhaust port, so you can direct the dust away from you or attach to a vacuum to it.
Also you can use a fan to blow the dust away from you. The blade is about $ 50.00, but worth it, if you cutting alot of cement board.
Dvanek12 is offline   Reply With Quote
Old 07-31-2011, 07:20 PM   #4
Rewards Points: 150
This is the blade you can use in any 7 1/4" circular saw. Most subs will buy the cheapest saw they can and use it until it dies. I would not suggest working any cement board with good tools as they will be destroyed. At one time and maybe they still offer it but the James Hardi Company would replace any cement board diamond blade free. All you had to do was send them the old blade and they sent you a new one. Might check it out if you are going to do much work with it.
TrapperL is offline   Reply With Quote
Old 07-31-2011, 07:58 PM   #5
DIY staff
Rewards Points: 7,174
Sounds expensive and dusty---I've got a wet cutting 4" circular saw just for cutting Durrock.
Harbor Freight has one like it for about $39.00
You just slap a wet sponge against the blade as you cut---no dust--clean cut.
You can cut Durrock just fine with a utility knife and maybe a jig saw with a carbide grit blade---
You need to justify the cost of a tool and the amount of use that it will get---and the time saved.
Old 08-01-2011, 02:30 AM   #6
Rewards Points: 562
thanks for replies, was thinkinking tile cement board tile backer as have 3 or 4 showers over tubs to do.hard to score and snap like 3/4 " hence cutting most of it anyway. The wet sponge saw sounds great. can you use a wet sponge with a regular circle saw or does it get the motor too wet? Cut some outside in wind, but did cut out a high vinyl window with a very slanted window sill under it while screwed to wall. A little less dust would be great.
Another potential use of the dual saw would be to cut vinyl siding for install and steel soffit panels for length instead of those hand shears. Does the saw cut siding and soffits clean?or jagged edged??
Old 08-01-2011, 05:54 AM   #7
DIY staff
The little wet saw spins slowly ----I think the wet sponge might be dangerous with a regular Skill Saw.
The little saw is worth the money if you have that much work ahead of you,
Hardibacker board vs Cement Durock board sukhenkoi Tiling, ceramics, marble 41 05-10-2017 07:38 PM
how to hang plastic behind shower cement board 4just1don Building & Construction 2 07-22-2011 11:34 AM
Correct detail of preformed shower pan meet the cement board of a shower wall eyeglass Building & Construction 0 08-31-2010 02:31 PM
Sawzall with Remgrit blade for cutting cement board Proby Carpentry 7 08-08-2010 04:47 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
