Drilling With An Impact Gun - Tools - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 04:52 PM   #1
Electrician
Proby's Avatar
Drilling with an impact gun
Impact guns are so nice and light that they seem to have taken over. The only thing I find myself using the cordless drill for anymore is drilling holes.
I was wondering how many people use their impact gun to drill holes? Most paddle bits already have the 1/4" quick connect shaft and they make normal bits with that shaft as well.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-20-2010, 05:49 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
i do it all the time with my makita impact. works great, although some times the paddle bits get stuck in the chuck. not sure if its just from the heat causing the shank to expand, but i usually just tap the bit on the side a few times and comes right out
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-20-2010, 07:00 PM   #3
Remodeling Contractor
Most bits aren't really designed to take the extra abuse from the impact action.
eisert is offline   Reply With Quote
Old 08-20-2010, 07:31 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
i've used them plenty of time, especially in wood. I haven't had any problems with bits wearing out early, only a little "sticking" in chuck, which is really nothing more than a minor annoyance
Old 08-26-2010, 10:50 PM   #5
The absolute best part of drilling with impact is NO WRIST STRAIN! I installed wiring for years and have permanent pain. Now I have a Makita impact and drill with nothing else.
onetec is offline   Reply With Quote
Old 08-29-2010, 11:46 AM   #6
I use my 12/18V impact driver to drill small pilot holes. I picked up a set of inexpensive hex-shank drill bits from HF. IMO its probably not wise to engage the impact mechanism drilling denser, deeper wood
aggreX is offline   Reply With Quote
Old 08-29-2010, 12:03 PM   #7
I'm not sure of why you're reluctant. My friends and I have been drilling holes up to 1 1/2" through single and double 2x4s with our impacts in a professional capacity (daily) for years. Of course, we spend on quality tools so I might be less enthusiastic with lesser quality drills. I would note that paddle bits seem to work much better than auger bits with impact drills.
Old 08-29-2010, 02:00 PM   #8
Thanks for sharing your big/better bit experience (I'll give it a shot) but the smaller HF bits can break in a small pilot hole. Under impact some hex shank plating may start to flake off or worse the hex-shanks can "mushroom" and get stuck in the chuck.
Old 08-29-2010, 02:26 PM   #9
Tom Struble's Avatar
Rewards Points: 2,002
http://www.makita.com/en-us/modules/....aspx?ID=20207
Tom Struble is offline   Reply With Quote
Getting impact windows ! Have two to choose from, which is best ? filo74 General DIY Discussions 13 09-01-2015 02:44 PM
Drilling asbestos siding (hanging shutters) MichaelDutch Remodeling 3 06-15-2010 10:49 AM
Help: Drilling into concrete or stud? rev1976 Building & Construction 7 05-11-2010 01:47 PM
Small impact driver vs. driver/drill Shrute Tools 17 05-02-2010 11:49 PM
Granite countertop drilling options dantm General DIY Discussions 1 02-09-2010 12:42 PM
