Drillbits - Tools - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 09:12 AM   #1
drillbits
Disclaimer: anyone who is for the ethical treatment of tools- stay away from my house, because I beat up tools regularly.
I'm sick of having incomplete drill bit sets due to my abuse of them and resultant breakage, dulling, and grinding. So, my plan is to have two good full sets- one for wood, and another for metal (and a handful of masonry as I need them). I suppose any old set is sufficient for wood, but metal is where I generally break them. What would you guys recommend as a good set of metal bits that will hold up to serious abuse?
OtisDriftwood is offline   Reply With Quote
Old 01-30-2011, 09:22 AM   #2
Rewards Points: 5,336
They do not exist. The smaller the bit, the less "abuse" they can take. Quite frankly any bit smaller the 1/4" is a consumerable in my mind. They break, it's just a fact of life. The larger ones can be resharpenen again and again.
Ron
Old 01-30-2011, 10:15 AM   #3
So I guess I should just keep extra small bits "in stock." I know that most of the kits I've had are cheapish, so I thought it might have been the quality.
I do want to get a good set of bits though, and I've learned that a sizeable price tag doesn't always equate to real quality- so, any suggestions? I don't generally have much need for giant bits, mostly smaller ones.
Old 01-30-2011, 11:47 AM   #4
Unibit for metal work. Depending on the metal you need to watch your speed and a little cutting oil never hurts....on heavier stuff atleast. Ron is right on about the smaller bits. Doesn't matter the who makes them, they break.
Mike
Mikelite80 is offline   Reply With Quote
Old 02-05-2011, 08:14 AM   #5
Drill bits a bad buy!!
May I add. please!
I purchased the new bits out there a five to a pack. They have blue stuff in the flutes. Well I would say don't waste your money.@#$#%^ I tried to drill a 1/8" hole in a 3/16" piece of soft steel and it took 3 min. I got out a small production drill bit from work and was through in about 30 sec. What a waste for drilling steel. I have not tried wood ?
I will add each bit cost about $ 5.00 each.
Robut
robut is offline   Reply With Quote
Old 02-05-2011, 12:05 PM   #6
Originally Posted by robut View Post
May I add. please!
Robut
Good advice to stay away from Smurf drill bits. I think the blue stuff was when Papa Smurf wasn't paying attention at the grinder.
Ron
Old 02-05-2011, 04:01 PM   #7
Don't know it all, yet!
I picked up a box of asst bits (Skil) at HD for $10 on sale. They were all smaller than 1/4 I think. All total 100 bits: 8-10 of one size, 4-5 of another. IMO a good multi pack of those that break or get lost so easily.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 02-05-2011, 04:06 PM   #8
Experienced
Jackofall1's Avatar
The old wise saying, and is always true, you get what you pay for
Old 02-06-2011, 01:09 PM   #9
Concrete & Masonry
Rewards Points: 568
The best way to get anykind of life out of steel drilling bits is to use a decent drill press vs. drilling by hand. A simple drill sharpener for the smaller bits doesn't hurt either. And neither does some cutting oil. I'm actually saving up for a bigger drill press right now that has a coolant system on it already.
jomama45 is offline   Reply With Quote
Old 02-06-2011, 05:32 PM   #10
Jackofall1,
I'm not clear on the point of your post re: you get what you pay for. Did you mean that $10 was a waste on cheap bits? The concensus seems to be that the smaller bits just seem to get gone, whether by breakage, dropping one in the grass or under furniture or whatever. IMO $10 to have some extra bits on hand as opposed to having to use whatever the next closest size on hand is saves time for me. So it's worth the $10 to me.
