Drill Wobble - Tools - DIY Chatroom Home Improvement Forum
Old 12-26-2012, 11:23 PM   #1
Drill Wobble
Ok. So I have heard every dern possible explination about a wobble in a Drill (not talking about Drill Press). How accurate should a Cordless Drill be? Some say it should be dead on, some say a bit of wobble is normal? (I am talking about wobble on the end of a long bit, not the chuck sleeve.)
VictorCDawg is offline   Reply With Quote
Old 12-26-2012, 11:27 PM   #2
Rewards Points: 558
Bits are not always 100% straight which in turn can cause wobbling…
epson is offline   Reply With Quote
Old 12-27-2012, 01:09 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Try different bits....if they all wobble, then your chuck shaft on the drill is bent.
What brand drill?
Old 12-27-2012, 08:17 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
no driver bit is dead straight as mentioned.. if it wobbles more than 1/4 throw out the bit as it can cause the bit to slip off a screw head.
low end cordless drills are prone to bad chucks. mastercraft maximum impact drivers are bad for this.. in the u.s they are sold as kobalt
woodworkbykirk is offline   Reply With Quote
Old 12-29-2012, 09:05 PM   #5
Hey guys sorry for the long pause inbetween post. The drill is of course a Black and Decker, which probably is prone to this wobble as mentioned. I just bought a Hitachi Hammer Drill and Impact Driver set and it does not appear to have the same effect, but I have a Dewalt with a Jacobs chuck I don't think should be doing the wobble as much as it should, but probably crappy bits is all I can think. Who has the best Bits to buy that are the most accurate is probably what I should be asking?
Last edited by VictorCDawg; 12-29-2012 at 09:25 PM. Reason: Jacobs chuck not clutch
Old 12-29-2012, 10:52 PM   #6
the best driver bits going right now are the milwaukee shockwave bits designed for impact drivers.. they are the most accurately shaped tips and last the longest of all the impact rated bits.. the dewalts are ok but dont last long.. ive bought just about every brand of bit available locally.. the no name ones are useless they dont last at all or they dont fit the screw recess properly.. bosch impact bits arent bad.. slightly better than the dewalts.
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 08:00 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 10:08 PM
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 10:53 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
