Drill Suggestions - Tools - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 10:50 PM   #1
Drill suggestions
I need a new drill. I have a cordless drill/driver that is awesome, but it's time to buy a corded hammer drill for man-sized jobs. I would like a reversible and variable speed drill that is good for home improvement type jobs, the first of which will be boring 1/2" holes through a great many floor joists overhead for electrical wiring.
I'm sure there are several people on this forum who have experience with such drills and could guide me to the correct choice, or at least steer me away from the drills that don't cut it in the real world. Thank you in advance.
-Jeff-
PaperJam is offline   Reply With Quote
Old 10-07-2010, 07:57 AM   #2
I bought one of these a couple years ago, and it's impressed me every time I've used it. With a good quality bit it eats concrete very nicely, and it laughs at treated 6x6 posts.
http://www.toolcritic.com/products/b...1194avsrk.html
I'd think all of the major tool companies have a decient small hammer drill, but this Bosch is my only experience with one. Only paid $80 for a reconditioned unit, but it seems this model has been replaced.
Have fun with the quest.
Bill
itin1200 is offline   Reply With Quote
Old 10-07-2010, 01:41 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Jeff, Welcome to the Forum,
For a corded reversible and variable speed hammer drill to be used for home use I would recommend a Harbor Freight model 67616.
http://www.harborfreight.com/1-2-hal...ill-67616.html
For home use drilling small holes through floor joists a would recommend a Harbor Freight Close Quarters drill model 92956:
http://www.harborfreight.com/3-8-eig...ill-92956.html
A set of spade bits with 1/4" hex shanks can be used in close quarters.
http://www.harborfreight.com/6-piece...-set-2728.html
For really close quarter drilling through joists, a spade bit can be chucked into the drill (to hold the bit if a vise is not handy) then cut the shank ~ 3" from the drill tip.
Drill suggestions-hf-hammer-drill.jpg   Drill suggestions-hf-compact-drill.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 10-08-2010, 06:57 PM   #4
milwaukie refurbs are the deal right now. check amazon, round 100 bucks for a drill that will last over a decade and outpower nearly anything
racebum is offline   Reply With Quote
Old 10-08-2010, 07:13 PM   #5
Safe, Most of the Time!!
brokenknee's Avatar
Consider how much you are going to use it. My brother in law purchased an economy hammer drill and burned it up in about three months. With that being said he is a licensed electrician and did use it a lot during that time. He did say that it worked good before he burnt it up.
I have a milwaukee and have been happy with it. Since I am not in the trades and only use it occasionally, I would think this drill should last me the rest of my life time. But then again the economy drill may have also.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 10-12-2010, 08:12 AM   #6
Thank you all for your helpful replies. I purchased a Milwaukee at Home Depot but have yet to try it out. It seems very heavy duty compared to the other drills on the shelf. I'll do some test runs with it and post the results later.
Old 10-13-2010, 02:46 PM   #7
Tool Geek
PaliBob's Avatar
Jeff,You can't go wrong with Milwaukee. I have two of them: a 3/8 inch Magnum with the keyless chuck and the old 1/2" D Handle Hammer Drill that weighs a ton.
Disclaimer
& Stay Safe
.....Bob Lavery
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Determining correct drill key MRTIGRE General DIY Discussions 3 06-04-2009 01:58 PM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 09:12 AM
