Drill For Mixing Joint Compound - Tools - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 05:47 PM   #1
MikeKy55's Avatar
Rewards Points: 254
Drill for mixing joint compound
I have a 1/2 drill/hammer drill and when I used it to stir joint compound, after a minute of two it began to smoke. Of course I stopped. Does it take a drill of a certain horsepower?
MikeKy55 is offline   Reply With Quote
Old 05-18-2011, 08:39 PM   #2
DIY staff
Rewards Points: 7,174
You need a heavy drill for mixing mud----I've used a Milwaukee Hole shooter for years--That's about the smallest you can get away with.
Harbor Freight has a mud mixer that a number of pros are pleased with.
I smoked a few drills ,long ago, Before I got a serious tool.---Mike---
MikeKy55 (05-18-2011)
Old 05-18-2011, 09:33 PM   #3
KemoSabe
loneframer's Avatar
If you want a drill that will give you years of service, look into a triple reduction gearbox. This drill turns at 450 RPMs. It will put a 1" auger bit through a PT marine piling. I also use it to mix bags of Sakrete in buckets.
Drill for mixing joint compound-002.jpg   Drill for mixing joint compound-001.jpg
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 05-18-2011, 09:49 PM   #4
MikeKy55's Avatar
Rewards Points: 254
That's the type mixing paddle I have. Guess I need more drill.....
Old 05-18-2011, 10:45 PM   #5
firehawkmph's Avatar
Rewards Points: 1,822
Mike,
I have a big milwaukee similar to what loneframer pictured. The key is the slow speed, lots of torque. It doesn't even break a sweat mixing thinset or joint compound. I think I paid 169.00 for it about 5 years ago.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
oh'mike (05-19-2011)
Old 05-18-2011, 10:50 PM   #6
Old School
Willie T's Avatar
I use an old Black & Decker that I got at a yard sale for $15.
Same mixing paddle as shown above.
Willie T
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 06:04 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 06:57 PM
